Help! Intake breather tube broke off!
Old Feb 22, 2015 | 08:22 PM
Heero's Avatar
Originally Posted by TheJuice401
just take it to a shop and stop bsing around..
If you've been on this forum long enough, you'll know that a lot of us enjoy fixing our cars by ourselves. I've owned my G35 since 2006, and because I take the time to BS around, I have saved thousands from the shops because I know how to fix them for the future. The simple solution is indeed to take it to a shop... At your expense of course.
Old Feb 22, 2015 | 09:54 PM
Heero's Avatar
Alrighty! Wanted to give everyone an update! It looks like my problem has been solved!
The battery drain didn't fix the issue.. probably because I only disconnected it for about an hour.
However, I stumbled upon this video on Youtube on how to do the Idle Relearn:
Skip to 2:35.
I found the best way to do the Idle Relearn is to actually count to 54, instead of count 1 through 3 or 1 through 10 each time. Once you count to 54, you should be flooring the pedal until the Engine Light blinks. Once it stops blinking, immediately let go of pedal and then turn car on.
I am now idling at approximately 600-700, and so far the past 2 hours of driving my Service Engine Light has not come on. I am hoping that it will stay this way.
Thank you JHereth22 for the hose method. That saved me from buying a new Z-Tube.
Old Feb 23, 2015 | 09:43 PM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by hurleyguys
I personally would just buy a new intake. you never know what could get sucked into the hole cause it is not getting filtered. someone is bound to have one close to you. or you could go to a junk yard and get one for cheap.
no need to get a new intake.
I actually have that hose completely off and venting into the oil catch can. The hole on the intake I just taped with electrical take. Nothing is getting through that .
Old Feb 23, 2015 | 10:06 PM
SxExCx's Avatar
It is so disappointing to see how much bad information has been given in this thread. Almost every response is wrong or misguiding.
The problem is that you are letting unfiltered and un-metered (post-MAFS leak) air into the engine. As long as there is any leak after the MAFS, the idle and throttle will not work correctly. All the resets in the world wont help.
There are only 2 safe solutions to the situation.
1. Buy a new intake tube and reconnect as if was before.
2. Cut the breather hose fitting off flush from the intake tube and safely/permanently patch the hole. If you go this route, you must remove the other end of the breather hose which is connected to the back of the driver's side valve cover and put an mini air filter in its place. The will vent the crankcase to atmosphere and prevent dirt from getting in your heads.
Old Feb 24, 2015 | 01:55 AM
JOKER's Avatar
CLUB MODERATOR
If he did the reset and idle revs came back to normal that means there is no air leak after MAF sensor. So he is ok with his fix and it's quite safe. If he gets a code again that means he's got a leak and will need a better fix.
Not everything needs to be fix with brand new shiny part. Sometimes piece of duct tape will do just fine.
Old Feb 24, 2015 | 09:08 AM
Jonlex99's Avatar
Duck tape, electrical tape, gorilla glue.. How bout just fixing it right.. Just a thought..
Old Feb 24, 2015 | 11:10 AM
SxExCx's Avatar
He already said that the glue /tape didnt hold. It looks like he needs a more permanent fix which would have been #2 that I suggested.
Old Feb 24, 2015 | 09:10 PM
saywat?'s Avatar
id replace the part. its not expensive to find a used intake but yea the info in this thread is pretty hilarious. funny people still suggesting the battery drain thing
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
