Window Issue
Old Mar 28, 2015 | 02:03 PM
G35Rican's Avatar
Window Issue
So my windows were working fine when I got the car and I had taken the fuses out thinking it would turn the a/c off when I was having that issue. But since than the windows refuse to keep constant power to them. I was able previously to push on the fuses and they would start working, now I have to turn the key off and back on as if its being reset. Is there any relay or anything associated with the windows that might be causing this?
Old Mar 28, 2015 | 09:12 PM
Siciliang35's Avatar
Its hard to understand what your trying to say. The ac has nothing to do with windows.
If you removed all the fuses , double check that they are in the correct spot .
Do both windows not work? Explain a little better and someone on here will be helpful . These guys on here are pretty good .
Old Mar 29, 2015 | 12:27 AM
G35Rican's Avatar
All the fuses are in the correct spot. I removed the window fuses when I first got the car thinking they were the a/c fuse. Since than I've had problems with power staying on for the windows, if I push the fuses with my finger power returns and I can roll them up or down but than power goes away. As of recently I have to cycle on the key switch for the pressing of the fuses to work. is there a relay that controls the window switch?
Old Mar 29, 2015 | 10:03 AM
Here is the service manual link i got from someone else on here .
http://psedog.com/cars/fsm/g35/coupe/2003/
Go to where it says gw
Old Mar 30, 2015 | 07:13 PM
G35Rican's Avatar
From researching wasn't even the window fuse I had messed with, was the 15A blower fuses. But crazy thing is that if I take those out and put them back in the windows work temporarily but than turn back off and have to repeat the process for them to work again. Any ideas?? I was thinking relay but have no idea which one would be for the window switch?
leo38cheng
Nov 12, 2015 06:49 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
