HELP!! ABS making noises when engine is turned off
Old Apr 12, 2015 | 10:47 PM
yelnats's Avatar
Hey guys I was driving on the road earlier and my ABS, VDC, and SLIP lights came on. I pulled over and shut the car off for 10 minutes and turned the car back on to see if the lights would go away. Lights remained on so I drove home and when I got home I turned the car off but I hear this noise coming from the engine, I believe the noise is coming from the ABS.
Do I need to replace my ABS module now or is it something else? Had to disconnect the battery to turn everything off.
Anyone know where the ABS relay is located?
Old Apr 13, 2015 | 01:38 PM
maxxcool's Avatar
O.0 sure sounds like a power fault.. it sounds like its just pumping its little heart out. obviously #1 stop will be a knechs\carequest\oreillys\autozone\pepdudes... get a scan code.
but yeah I will bet the control module is shot.
Old Apr 13, 2015 | 10:01 PM
partyman66's Avatar
Those lights can all come on when your brake pads are really thin and need to be replaced. Have you checked them out at all recently to inspect for pad runout? Can't see your video at the moment since my job blocks youtube.... so this suggestion is possibly partially incomplete.
Old Apr 15, 2015 | 02:34 PM
yelnats's Avatar
got the car scanned and got c.1111 ABS Power Relay Coil Open Circuit
I think the ABS relay has failed so I have gone ahead and ordered a new one. Did some research on this forum and a couple others have had the same issue and replacing the relay fixed the problem so I am hoping mine is the same. Will report back once I have swapped the relay.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
joedaddy1
Jul 28, 2015 02:58 PM
Thaaa_king
Jul 18, 2015 05:56 PM
