anyone else having their batteries die really quickly?
Old Feb 19, 2005 | 07:46 AM
g_thirtyfive's Avatar
maybe cause i havent driven it for a month or so, but this was a brand new replacement battery from infiniti, and a month later coming bak from vacation, i cant start my car again...anyone else have a JL w7, with a 500/1 amp, and a ddx7015 head unit (a capicitator too) and having their batteries die on u? second battery might i add...
Old Feb 19, 2005 | 09:09 AM
Brando's Avatar
Nope. My early 03 is still strong.
You need to buy you a trickle charger like the Battery Tender if you are going to let if sit for weeks at a time.
Old Feb 19, 2005 | 09:23 AM
Andy77's Avatar
This sounds unusual. Unless the car has been very cold, and was very cold when you tried to start it, the battery should have been good after a month of "rest." It is possible you have a defective replacement, but I'd look for a device that is draining the battery while the car is off. I guess the other possibilty is that the charging system isn't working so it never replenishes, but then a dash light ought to come on. Maybe the squirrels were listening to your sound system while you were away!
Good luck-let us know.
Old Feb 19, 2005 | 10:56 AM
TINMAN's Avatar
infiniti's batteries are suck.i repeat SUCK.a lot of people having problem in the past including me.so juat change to a different brand battery and be done with it.
Old Feb 19, 2005 | 12:14 PM
ajayjuneja's Avatar
which brand do you use, Steve? Optima?
Old Feb 19, 2005 | 04:23 PM
^ i'm not too sure...i never checked, all i know its a infiniti replacement. i do have a lot of electronics running, but then again that still shouldnt happen. the battery cant be really cold since my cars been in teh garage the whole time. i dont even have away of jumping it now lol..i parked it in front end first cause i didnt think it would die again..hahah ****
Old Feb 19, 2005 | 04:24 PM
i was going to get a replacement battery, but y pay for one if infinitis gonna pay for one for me? :P
Old Feb 19, 2005 | 04:27 PM
Potty_Pants's Avatar
cause they will buy a replacement piece of crap
Old Feb 19, 2005 | 07:20 PM
Msedanman's Avatar
O.F. Administrator
Could be the amp, especially if you run it much with the engine off, or if it uses juice faster than the alternator can restore it.
Could be a slow leak such as a light left on for example in the trunk.
Have a static test done on the system to determine this. If all is well, then you need a heavier duty battery like an Optima.
Old Feb 19, 2005 | 08:22 PM
TINMAN's Avatar
i bought a Duralast from Autozone.
because they will replace with ANOTHER SUCK BATTERY.
Old Feb 19, 2005 | 08:39 PM
Lucino's Avatar
man, you are pissed.
I have no problems so far wit the battery
Old Feb 19, 2005 | 08:42 PM
MaDdFLaSheR's Avatar
question... the dealer told me that leaving the assheaters on when the car is off drains the battery.. i dont see how thats possible since the seats dont heat up with the car off. is this another dealer myth or does the battery actually drain?
Old Feb 19, 2005 | 11:24 PM
Andy77's Avatar
"the dealer told me that leaving the assheaters on when the car is off drains the battery.."
I can't see how that could be true. Mine are always on in the winter and
1) my seat is cold when I sit down in the morning!
2) my battery is not dead.
BTW, when Infiniti replaced my I30 battery when it died after about 2 1/2 years, the replacement lasted about 3 1/2 years. It was a weird story-I stopped by the dealer on a winter Saturday afternoon to say hello and look at cars and then went to my office for a few hours of paperwork. When I left, the car barely turned over. After it caught, I called the dealer to see if they could replace the battery then, and of course service isn't open on Sat. I asked if I could bring the car up so they could change it on Monday and could they give me a loaner until then. My salesman said sure, and an Infiniti loaner was waiting. Most brands would not go out of the way for you.
Old Feb 20, 2005 | 01:00 AM
DiamondGCoupe's Avatar
Make sure you add water to the batteries once a month or so, especially in warmer climate. I check mine about once every two weeks, and there always about 1/4 low.
Old Feb 20, 2005 | 02:38 AM
kenchan's Avatar
I let my car hiberante during the winter and the last time I checked/charged the battery after letting her sit for 3 weeks, the charger indicated that the battery lost very little power...so it should last a good 6-7 weeks even garaged in 34F.
