my car Is missing something.
I'm looking into spacers now, the rims do have that sunken in look and want to go pretty aggressive. My specs go as follow:
19x9.5 22 offset 225 - 35 - 19
19x10.5 22 offset 255 - 35 - 19 rear fenders rolled
Looking to get aggressive with the spacers 25/30 mm sound good or too much?
If you don't care about adding weight to what already look like (but may not be) heavy wheels, just add 25-30mm spacers and you should get the "aggressive look" you want.
If you want to do it right (performance AND looks), buy lighter wheels that have the correct offset and skip spacers.
Wouldn't that be too small? I'm thinking of 20 front and 25 rear now.
if you want a crazy stance look.. then yes, it would be too small. but if you want a flush/static look, then 20 front and 25 is too much, especially with your drop. you're going to need camber arms as well if you go that wide
He said he wants to go pretty aggressive. What you just said to do will leave him still looking like the titanic lol
Not sure if srs
His original specs are Weak as hell for "pretty aggressive"
I went even lower this past weekend for the infiniti vs honda meet which sucked because of the rain, I scrape my exhaust over high bumps if I don't get a perfect angle and it sucks still. Im still good on the 20/25 mm right
You 100% will need a camber kit if you go 20/25. Your tires will be touching your fender, look how thick 25mm spacers are lol. I would honestly go 10/5 for a flush look. If you want "aggressive" then 25/20 will work but you're gonna have to raise your car or get a camber kit for sure.
10mm spacers would leave him flush..
Agreed, but 30mm spacers would bring him past that.. plus hes lower than you so it wouldnt work unless like I stated before, he gets camber arms
Or....... you do 10mm spacers and have a nice flush look. Like you said, everyone has their view of "aggressive". and with his drop, 30mm spacers wont work alone.
should of went with a square set up with 10.5s all around. But do the 30mm up front 20 mm in the rear. that will make your "poke" even all around and it should clear with stock arms you might have to pinch your front fenders flat.
Your specs would be as follows
19x10.5 +2
19x9.5 -8
19x10.5 +2
19x9.5 -8
I'm still not quite sure why you're so worried about everything else and are paying no attention to the fact that your trunk is not painted... It's really the most obvious thing that needs to be done before any more money goes to anything else.
