need help on what to get
Old May 3, 2015 | 02:06 PM
g35jdm's Avatar
I'm going to purchase varrstoen es1 wheels and need help on a couple things. i need to know what spacers to get, what size tires to run, and what else i need? I'm buying these wheels right after i post this. they are 19x9.5 and 19x10.5. i looked around but i need a clear decision on what to get to make sure i order all the right things. i already ordered coil overs for the car. if you could help out thanks. i want a little stretch on the tires but nothing crazy.
Old May 3, 2015 | 02:34 PM
Lartytiejdke3's Avatar
Buy different wheels
Old May 3, 2015 | 04:27 PM
Urbanengineer's Avatar
Offsets tell us how they fit on your car. You've got to include that info.
Old May 3, 2015 | 05:45 PM
g35jdm's Avatar
Condition: New Rim Brand: varrstoen wheels
Number of Bolts: 5 Rim Material: Alloy
Bolt Pattern: 5x114.3 Rim Width: FRONT 9.5/ REAR 10.5
Hub Bore: 73.1 Rim Diameter: 19
Rim Structure: One Piece Offset: FRONT +12 / REAR +12
Old May 3, 2015 | 06:11 PM
Nice good offsets. How low do you plan on going with the coilovers and do you have camber kits.... Thanks.
Old May 3, 2015 | 06:28 PM
g35jdm's Avatar
don't have camber kits. and just enough so theres not much of a gap between the wheels. I'm gonna put a 245/35/19 tire on the front i already bought them. and need help quick deciding what tires to put for the rear
Old May 4, 2015 | 10:33 AM
gary c's Avatar
A pair of 285/35X19s will fill up those 10.5" wheels nicely, good choice on the front tire size! With that offset you won't need spacers, you may need to have your rear fenders rolled. You will need a camber kit unless you plan on replacing those new tires every 8 to 10K miles, it's cost effective to do so!
Gary
Old May 4, 2015 | 11:13 AM
VenomGT9's Avatar
If you want a little stretch, 275/35 wouldn't be a bad choice either... it'd be .5% too fast whereas 285 is .5% too slow. I would also suggest getting the fenders rolled regardless, always good to have that extra room if you end up needing it.
Old Jun 2, 2015 | 01:08 AM
6mt_Ramon's Avatar
I'm going to buy the same wheels, same offsets. I am lowered on coils about 1 finger gap front and back. I am aiming towards flush. Would the +12 offset give me that? im thinking 245 in the front. But for the rear would 285 or 275 give me any rubbing?( I will roll my femders) any advice would be great. Thanks
Old Jun 2, 2015 | 03:34 PM
6mt_Ramon's Avatar
Bump
Old Jun 2, 2015 | 06:23 PM
WhosUrBuddiee's Avatar
Buy better wheels.
