235/35-19 Front Tires on Rays Forged?
May 21, 2015 | 01:09 PM
Hey guys,
Would there be any negative side effects to running a 235/35-19 tire on the front with the stock Rays forged rims?
The tire is 97.66% of the circumference of the stock 245/40/19. Would this cause speedo issues? Or is the speedo run off the rear tires?
Thanks
Reply 0
May 21, 2015 | 01:45 PM
You'll be fine
Reply 0
May 21, 2015 | 07:51 PM
You'll be ok, although the speedo might be off just a little (but not significantly).
Reply 0
May 22, 2015 | 09:01 AM
Most of us with aftermarket wheels run at least 245s in front so the 235s won't be a problem with the OE Rays...Gary
Reply 0
May 24, 2015 | 12:13 AM
Thanks guys! Was in a bind and that's all they had around in tires I liked. I find the 235's way more grippy! No understeer in hairpins whatsoever
Reply 0
