04 g35 Radiator fan help
Old Nov 15, 2015 | 05:40 PM
Victor Hugo's Avatar
Newbie
My 04 G35 coupe has been over heating for the past month. I changed the thermostat and now Im flushing the system with OEM Nissan Coolant. I'm circulating distilled water right now and then im going to dump it and add the 50/50 OEM Coolant. While i was running the car waiting for my Fans to start spinning. I noticed that only the DS Fan is spinning. i waited to see if maybe after a little more the PS Fan would kick in but instead the DS Fan just started spinning faster/louder. Are they supposed to both turn on at the same time @ all times? If so, what should i check for? The cooling fans relay cannot be replaced can they? Will the not mess up the module?
Thanks everyone for help and advice!
This is the video im following, im @ vid #9
http://www.carcarekiosk.com/video/20.../flush_coolant
Old Nov 18, 2015 | 08:49 AM
Duriisimo's Avatar
Fan motor maybe done
Old Nov 23, 2015 | 01:39 PM
telcoman's Avatar
Veteran: Army
Why not follow the steps in the FSM?
http://www.nicoclub.com/FSM/G35/Coupe/2004/co.pdf
If so, what should i check for? ]
Voltage at the fan motor
Check the motor winding with an ohmeter
Telcoman
Old Dec 1, 2015 | 08:59 AM
Duriisimo's Avatar
any word on this?
magnetism80
Feb 1, 2019 10:00 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
FRUG35
Aug 31, 2015 02:33 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
