G35 running rich
Old Nov 28, 2015 | 05:14 PM
Aaroncg28's Avatar
G35 running rich
Hey guys so I've had my car for a while
when I first got the car (stock) I was getting around 18-19 mpg avg
but now that I added a few mods it's only giving me 14-16 mpg
I noticed that the mpg loss was when I disconnected the battery (reset)
and started driving it a little bit fast, I understand that now the car
cruises in a lower gear to get a faster response but that doesn't explain me the richness
it's dripping a lot of fuel out of my exhaust
would a tune help on this situation or whats a good option?
added mods:
TDX2, Spacer, Drop in KN, Berk HFC on the mail
Old Nov 30, 2015 | 07:07 AM
VenomGT9's Avatar
Are you positive it's fuel coming out of your exhaust?
Old Nov 30, 2015 | 10:29 PM
partyman66's Avatar
Is your Check Engine light on?
There's no reason that your car should now cruise in a lower gear unless you did some sort of auto-tranny ECU reprogramming or swapped in a different rear end or swapped in really different outside diameter tires.
Old Dec 1, 2015 | 12:35 AM
EPiK's Avatar
Leaking injectors? What mods did you do?
Old Dec 3, 2015 | 12:30 AM
Aaroncg28's Avatar
I have the oxygen sensor light on
(which I don't know why because I replaced it)
and I'm not sure if the injectors are leaking to be honest
tomorrow I'll be replacing my cats with HFCs
and I'll clean out my sensors and check if something is wrong with them
Old Dec 3, 2015 | 12:40 AM
EPiK's Avatar
Did you turn off the check engine light after you replaced the oxygen sensor? And be careful of putting high flow cats in there if the injectors are leaking you will be wasting a lot of money because they will get melted right out.
trini35
Jul 5, 2025 04:13 PM
G35sedan89
Nov 15, 2015 03:15 AM
SrT4_OwNeR
Nov 12, 2015 01:02 PM
ncg35guy
Nov 7, 2015 12:20 AM
