Window motor giving me a hard time
Old Feb 7, 2016 | 05:40 PM
Jdsierra9's Avatar
Ok so my passenger window stopped rolling down about a week ago. At first I thought it was the motor so I ordered one from Amazon. Got the motor, followed all the steps to remove the door panel, and plugged it in. As far as I know, the motor should work as soon as you plug it in (correct me if I'm wrong)... It didn't. I bought another one from autozone and it didn't work. At this point, all I'm worried about is to get that window up again so that I can leave it outside and then fix whatever it is that is not working. Any help would be greatly appreciated. It is a 05 g35 coupe btw.
Thank you guys
Old Feb 7, 2016 | 08:47 PM
deeliciousqueen's Avatar
G35 coupe 6mt
did u do the reset procedure? it could also be that you have a dead window switch.. also check window regulator
Old Feb 7, 2016 | 11:33 PM
Jdsierra9's Avatar
I did try the reset procedure but it didn't work. Probably I did it wrong.... I'll try again tomorrow. I also tried the bang method with no luck
Old Feb 8, 2016 | 12:34 AM
coffeysm's Avatar
Don't attach the motor to the door and press the switch. If it spins then odds are you need a new window regulator.
You might be able to push it up by hand if you have the inner panel off.
Old Feb 9, 2016 | 12:48 AM
Mignav01's Avatar
Might be your regulator, I'd check that along with your actual window switch. maybe something isn't working there. But if I had to guess with the cars age, it's probably the regulator
Old Feb 9, 2016 | 07:46 PM
saywat?'s Avatar
im confused so does the new motor allow you to move the window or not?
Old Feb 10, 2016 | 02:33 PM
Mignav01's Avatar
The motor powers a set of pulleys that raises and lowers the window
Old Feb 10, 2016 | 02:34 PM
saywat?'s Avatar
im asking op. he said the motor doesnt work but u guys asking him to do the reset. thats wat im asking.
Old Feb 10, 2016 | 02:35 PM
Mignav01's Avatar
Oh okay. my bad
Gdup35sedan
Interior
Feb 12, 2024 11:27 PM
AlexxRyzhkov
Jan 31, 2016 11:25 PM
twenty5
Jan 30, 2016 04:42 PM
guod
Jan 17, 2016 12:42 PM
Dallsinghjr1
Jan 14, 2016 05:10 AM
