oil catch can
False information!
Your OEM system is not closed.
Valve cover on the left head is closed off by PCV valve. The one on the right is not. It plumbs into the intake tube which is constantly open.
So there are no need to maintain a closed system.
Everything is a preference.
Most closed catch cans designed to vent only one head. People forget that we got two and there is another line that vents into the intake.
With open can you can vent both. I like open because I guarantee that there is no oil vapor goes back into the intake, with closed you cant. Some vapor still escapes no matter how good your can is.
With open can you do have to deal with oil smell outside the car. Easiest way to manage it are oil soaking pads that you just replace with oil change and never have to worry about your can filling up with oil.
Best can design IMO would be a closed can that you can open and put oil soaking pads in. This would be a 100% can that has no smell. Oil pads would absorb all oil vapor and never release nothing back into the line as long as you replace them frequently.
I agree. Baffled catch can is essential for a closed system. Goal is to keep oil out of the intake manifold. In the long run, your valvetrain stays clean and so does your intake tract for long term performance. I do advise swapping the PCV One time if installing to eliminate any problems that may come down the road.
Gary
even the port from the rear driver valve cover going into the intake is part of a closed system. it is after the maf... metered air. so just make sure that you plug the port in the intake tube from that valvecover port if you want to run an open breather, otherwise it will leak metered air and won't run properly.
I'm going to work on mine today. can needs baffles, maybe a restrictor
Jonnyidfw
Engine - Intake/Fuel
13
Mar 15, 2016 03:26 PM
