Help with Oxygen connector
Old Mar 2, 2016 | 10:42 PM
prjoker's Avatar
Hello everyone im alittle suck with finding the Oxygen connector female side (right side) its the part of the engine/ecu harness. I need to replace the connector cause it got damage when the retread ;smack Baby I knoe i can directly splice to the O2 but i want a connector for a OEM fit. thank for any sites that have a repair kit or if u got a harness laying around i can bye the connector from. thanks agian
Old Mar 3, 2016 | 09:56 PM
prjoker's Avatar
any help????
Old Mar 3, 2016 | 10:50 PM
partyman66's Avatar
Translate into English.
Old Mar 4, 2016 | 10:43 AM
LoSt180's Avatar
It sounds like you need what's called a harness "pigtail" for the O2 sensor. If your old one was ripped off by a tire tread in the road, I'm going to guess it was the sensor #2 (or downstream) sensor that got damaged. These cars have four O2 sensors, so you'll need to be more specific on which connector you need.
You can probably get them from a junk yard. A friend of mine has a spare engine, I can ask if he's willing to cut connectors off.
Old Mar 4, 2016 | 11:03 PM
prjoker's Avatar
its the right handside downsteam female O2 connector
Old Mar 8, 2016 | 05:12 PM
prjoker's Avatar
Old Mar 8, 2016 | 07:45 PM
rdozier's Avatar
Try a junk yard though they maybe hard to find there. The pull your own part yards are generally cheaper that I have found. But then again I have not found a vehicle(much less a g or z) with the right engine in any of those yards. Can try ebay to.
MoJ
Jun 3, 2016 10:17 AM
aznvictobear
Feb 7, 2016 10:32 PM
08STLX
Feb 5, 2016 01:44 PM
teahead
Lights
Dec 23, 2015 06:06 PM
GR8TG35
Oct 4, 2005 04:38 PM
