Need help
Old Mar 5, 2016 | 12:34 AM
Jonathan Ayala's Avatar
Need help
can someone please tell me what this is
Old Mar 5, 2016 | 05:17 PM
partyman66's Avatar
Sorry to tell you but that motor is done.
Old Mar 5, 2016 | 05:19 PM
i knew it okay thanks
Old Mar 5, 2016 | 07:26 PM
partyman66's Avatar
I see you have a Rev-Up G35 based on your tach.... check the oil level, it may be almost empty which could have caused the failure. Oil consumption is a common problem on those motors.
Old May 18, 2016 | 01:15 PM
Can i replace the motor with a automatic or is ther too much of a different
Old May 18, 2016 | 09:01 PM
G34.5and1/2's Avatar
You can use an engine that had an automatic trans in your manual shift, just use your flywheel on the engine and bolt her up. Gee I made it sound so simple are you done yet. I would guess from this question you have never swapped an engine before. This is not something you want to start learning auto mechanics 101 on, you will need a good friend who knows what they are doing or pay someone to do it and that someone needs to be a skilled mechanic that does this very thing for a living not someone that changes his own oil. Yeah buddy I can do that fur a couple hundred bucks, run away , run away fast!
Old May 19, 2016 | 10:19 AM
coffeysm's Avatar
It might be possible, but you'd have to remove torque converter and put the flywheel on. The MT also has some more sensors than the automatic (exhaust VTC solenoids come to mind). Not something for a novice to do.
acuteperformance
V36 Brakes, Suspension, Wheels & Tires
Jun 13, 2009 02:49 PM
acuteperformance
Jun 13, 2009 01:56 AM
