Engine build and custom projectors
Old Mar 28, 2016 | 06:26 PM
ogrudy's Avatar
What's up guys I need some input on what I should do I'm getting my engine built by a friend and i ordered high compression Pistons because I didn't have the extra cash for the turbo yet. is it really a lot safer to go low compression with turbo or will I be fine using high compression Pistons? My goals are 450whp. I ordered eagle rods, wiesco pistons, complete acl bearing set and arp main and L19 head studs. I also recently had some custom headlights made they are the 06 projectors with a e30 lens up top on the stock projector with a morimoto projector on the bottom with the gatteling gun shroud. But my favorite part is the orange lens was carefully dremeled out and a projector lens was put in its place.
Old Mar 29, 2016 | 06:11 PM
Mignav01's Avatar
with high compression it won't take as much boost to be hitting some serious numbers. Although you're going to need an extremely good tuner and to make sure your whole engine can stand the power levels your looking for
Mike@CZP
Engine-Vendor
97
Jan 18, 2018 01:23 AM
94z28joe
Engine - Complete Motors
Mar 8, 2016 09:12 AM
Siciliang35
Jan 17, 2016 09:43 AM
