Need help with the name of a couple of sensors.
Old Mar 28, 2016 | 09:09 PM
Jonny15T's Avatar
Hey all,
So on Saturday while driving home from my parents house, my 2005 G35 Coupe died on me out of no where. No spudder or noises, just died. Upon inspection I found that the belt that connects to my A/C had broken and the other belt was severely frayed. The SLIP & VDC OFF light are now on when the key is turned to ACC but no CEL. While on the side of the freeway I attempted to restart my car and could get it to crank, but not turn over.
I decided to go ahead and replace the belts and while doing so noticed the wire to the connector to the green sensor was nearly severed. I fixed it and made sure there was a full connection and so on, so I don't think that it has to do with a faulty repair.
I'm still having the issue and couldn't find any other wires that were damaged when the belt broke.
I've read it could be the camshaft position sensor, but it just seems like too much of a coincidence that it failed at the same time my belt broke.
Anyway, I've circled the sensors below that I can't seem to find the name of and the left (green) connector was the one with the damaged wire.
Attached Thumbnails Need help with the name of a couple of sensors.-img_0975.jpg
Old Mar 28, 2016 | 10:11 PM
hurleyguys's Avatar
i would bet thats the cam position sensor but i dont know for sure. they go bad on a lot of g's.
Old Mar 29, 2016 | 01:29 AM
coffeysm's Avatar
Those are the exhaust valve timing sensors (EVT) they are only on the MT.
NJ6MT
Feb 24, 2016 07:24 PM
edwinisdumb15
SOCAL Meetings & Events
Feb 7, 2016 09:57 AM
Velix
Jan 17, 2016 10:07 PM
mjfenix
Jan 8, 2016 05:17 PM
