Tire Up-Sizing on 03
Old Apr 18, 2016 | 07:17 PM
Rhinoe's Avatar
I am looking for some suggestions on the tire size for my 03 G35 6mt coupe, with brembo's. I have no modifications and I do not intend to modify. All of my tires are pretty bald and it is time that I replace them all around ... I was looking to go larger than the stock sizing that I have currently: 225/45/18 (front) and 245/45/18 (back).
I only intend to keep this car for another year so I am not looking to break the bank here, but it seems to me that the cost between same size tires versus larger tires is negligible. How big can I stand to go, stock (OEM 18" wheels, spacing, etc) without needing modification?
I have done some searches, but not finding clear answer. I was thinking about doing 245/40/18 on the front and 265/35/18 on the back.
Old Apr 18, 2016 | 07:44 PM
ScraggleRock's Avatar
Do NOT go 265/35 on the rear. That sidewall is the same as the 225/45 front wheels. You have to go 275/40 to get the same diameter as stock but have a wider tire. If you get 265/35 it will look dumb af.
Your front 245/40 idea is right on tho. That's the same diameter as stock front tires but 20mm wider.
I don't know how/if a 275 can fit on the stock wheel tho. I have 275/40 on a 9.5" wheel. Someone else chime in and tell him if a 275/40 will fit on an 8" wheel
Old Apr 18, 2016 | 07:58 PM
Rhinoe's Avatar
Thanks man. I did some research off that and it looks like my stock wheels won't work with 275, unfortunately. I am now wondering about a 245/40/18 front with 255/40/18 rear .. ?
Old Apr 18, 2016 | 09:15 PM
You'll still be losing decent diameter with 255/40. You could do 255/45 and it would actually be about 1.1% taller, but the only way to keep the same height is to do the 275/40. Losing diameter is not recommended at all unless you plan on lowering to close the wheel gap.
Old Apr 18, 2016 | 10:07 PM
partyman66's Avatar
275 won't work on stock rims. You can do 265 but then have to find a front tire whose diameter doesn't throw off VDC as a result of the front to rear size difference... which is a bit tougher considering aspect ratios are always in gradients of 5 or more. Maybe keep the stock rear size and go 245/40/18 up front. I had that setup for a while but went back to 225/45/18 up front because the tire I wanted wasn't available in the 245/40/18 size. Unless you're doing aggressive racing I doubt you'll notice anything and your tires might actually last a bit longer with the stock size unless you've gone to aftermarket fully adjustable control arms with a more neutral alignment. I really like my Nitto Motivo tires on the G so far. 10x the tire my crappy Falken FK452's were. I wouldn't recommend Falken to anyone based on my experience with them, and the stock Michilin PIlotsports wore out fast, slipped a TON in the rain, and cost too much.
Old Apr 19, 2016 | 11:09 AM
Rhinoe's Avatar
Feeling that you may be right and I may just go stock sizing all around. Looking at the BFGoodrich All-Seasons.
mdzukunft
Apr 28, 2016 02:22 PM
silverG2007
Apr 16, 2016 03:32 PM
edin_g35
Apr 15, 2016 02:59 PM
ChandlerL
Apr 14, 2016 01:57 AM
Jdmay35x
V36 General Tech Questions
Apr 13, 2016 06:55 PM
