Cooling fan operation
Old Aug 3, 2016 | 10:21 AM
mbe32's Avatar
My '06 G35 only seems to have one cooling fan operating. What are the operating conditions for the cooling fan?
When I turn the A/C on the passenger side fan comes on but the driver's side stays off. Is the driver's side fan only suppose to come on if the engine temperature or A/C pressure reaches a certain point or do I have a defective fan?
I've heard the fan motors are common to go bad. An aftermarket motor made by TYC is about $50 but I would like to confirm fan operation and do some basic checks of the fuses/relays before I replace the motor.
Old Aug 3, 2016 | 11:28 AM
telcoman's Avatar
Veteran: Army
You can find the info you are looking for in the FSM
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/co.pdf
See page CO-021
Cooling fans are controlled by ECM. For details, refer to
EC-526, "
DTC P1217 ENGINE OVER TEMPERA-
TURE"
Check the voltage at the fan. Most likely a defective fan
Replace both of them
Telcoman
Old Aug 3, 2016 | 08:02 PM
partyman66's Avatar
The ECM controls the cooling fan corresponding to the vehicle speed, engine coolant temperature, refrigerant temperature, and air condition ON signal. The Fan system has a 3-step control [HIGH/LOW/OFF].
See the linked image for specifics of how the fan is supposed to operate based on various conditions:
This is for an '03... probably the same for an '06.
Old Aug 4, 2016 | 10:11 AM
mbe32's Avatar
I have a multimeter to make some checks.
How would I go about doing a voltage test on the fan motor?
Old Aug 4, 2016 | 10:24 AM
telcoman's Avatar
Veteran: Army
Have you even looked at the FSM in the link that I provided in my previous post? (Start on Page EC-531)
Don't take this the wrong way but the fact that you are asking how to perform a voltage check on the fan motors when that information is clearly shown in the FSM leads me to believe you would probably be better off leaving the troubleshooting to a professional.
Telcoman
Old Aug 4, 2016 | 10:30 AM
mbe32's Avatar
Telcoman
Yes, I did as a matter of fact. But there is no information on testing from that link as the section EC-531 does not come up when I click on the link in section CO 21.
Thgame109
Jun 10, 2023 11:27 PM
Thgame109
Mar 18, 2016 12:04 AM
TYJUS
Midwestern
May 7, 2012 05:34 PM
stalker
Canada
Dec 18, 2002 09:44 AM
Mr_G35
Oct 10, 2002 11:15 AM
