Wheel hub?
Old Oct 10, 2016 | 09:27 AM
RMSpiel's Avatar
Wheel hub?
Hey guys so when I'm driving over 40 mph I feel/hear a humming. It's intermittent but goes about 2 times a second. If I turn slightly right, it stops. If I turn slightly left, it gets louder. This leads me to believe that it is the front left wheel hub. What do you guys think?
Old Oct 10, 2016 | 10:06 AM
Urbanengineer's Avatar
Could be the tires or the wheel bearing. If you have a set of winter wheels or an emergency spare, swap that wheel to see if the sound continues.
gary c's Avatar
Quite often what you're hearing is caused by those groves in the road! Turning your wheel changes or stops what you're hearing...Gary
Old Oct 10, 2016 | 11:27 AM
RMSpiel's Avatar
Thats what I thought at first, but the sound occurs on every road. Rough, smooth, newly finished. Doesn't matter what road. This is what caused me to believe that it is the wheel hub. Also since no matter what the sound goes away when turning slightly right, and gets louder while turning slightly left, no matter what road.
Old Oct 10, 2016 | 02:02 PM
BradMD_96's Avatar
If you have a non staggered setup, swap the left front and rear. You could swap fronts side to side but if they're directional it might be a problem in the wet.
Old Oct 10, 2016 | 02:04 PM
I already gave him the tools to figure it out but he ignored it.
Old Oct 10, 2016 | 02:09 PM
LoSt180's Avatar
Since it gets louder when slightly turning left, then it's most likely a wheel bearing on the right side of the car. You can jack the car up and try the "shake test" but I found that didn't work when my rears went bad. Mine was solid and couldn't "feel" the problem until I had already removed it.
Old Oct 10, 2016 | 02:20 PM
partyman66's Avatar
The factory rims have notches in the rim and hub to prevent putting front rims on rear hubs and vice versa.
Turn the front wheels all the way to the side and get out and look at the tires for wear on the inner edges. The aggressive stock alignment leads to rapid inner tire wear on the front tires which creates reverberating sound that could be what OP is hearing. Also check your tire pressure to make sure it's within spec.
Old Oct 11, 2016 | 11:03 AM
RMSpiel's Avatar
Didn't ignore what you said, haven't had time to go out there and swap on the spare. I'm a full time student with a full course load. Luckily I dorm so don't commute but have time tomorrow so will give this a try.
Old Oct 12, 2016 | 01:49 PM
CFE4130's Avatar
I think I have the same issue, but mine occurs over 60mph. I noticed it after I installed a new front lower control arm. I switched up the front wheels and it didn't change. I'm going to re-torque the control arm bolts to spec today and see if it changes
Old Oct 13, 2016 | 07:19 PM
Gigi_G35's Avatar
Mines is doing the same exact now... Also when I brake at high speed I get wiggle in one wheel.... Could be plenty things... Take it to Meineke if you have one around, they will diag is for FREE! Only takes them 20-30mins max
Old Oct 14, 2016 | 04:49 AM
Blue Dream's Avatar
I drove ttrank's car solo
Quite often what you're hearing is caused by those groves in the road! ...Gary
Those damn groves shoudn't be in the road.... What are the groves doing in the road??
How are we going to pick the oranges if the groves are in the road?!?!
Old Oct 14, 2016 | 05:04 AM
Blue Dream's Avatar
Nooooooooooooooooooooooooooooooooooooooooo!! No Meineke, Sears, Pep Boys, Jiffy Lube, Goodyear, Firestone etc. should ever touch a car. They hire mostly sub-par "mechanics" who would rather be at home scratching their ba!!s than working on a car. Find a local mechanic that's been around your community for a while, Yelp is a good place to start looking for one, and take it there. Way too many horror stories across the web about these generic chains that claim to do good work on vehicles. Went to a local Firestone to get a quote for a replacement radiator and thermostat on the G. Quoted me $691 for all parts and labor so I laughed a bit and went to rockauto, ordered a Denso rad. and a new thermostat. Shipped to the house for $93 total so with a gallon of concentrated Prestone and a gallon of distilled water fixed her myself in a little over an hour for $100.
Now I get not everyone can DIY even a simple project like this but I tell my story to prove a point, chain auto repair shops are out there for one reason, to make a lot of money on suckers who trust them. Go where you want people but when you get fvcked I'll be happy to say I told you so.
Old Oct 14, 2016 | 11:40 AM
Gigi_G35's Avatar
Meineke has free diag for that simple issue, just pulled here now, I'll tell you guys what's the problem in a bit
Old Oct 18, 2016 | 04:46 PM
RMSpiel's Avatar
Yeah I prefer to do the work myself. Im coming from owning a wrangler in which for the past 3 years I've done a majority of the work myself (everything except welding). This included full suspension (lift, control arms, shocks, track bars), transfer case work, engine mounts, tranny mounts, axle swaps, fluid flushes and changes, etc etc.
I have no issue doing work myself as long as I know what exactly is wrong. If I can't figure it out I have two trusted mechanics I only let touch my vehicles. One family friend, another a friend of mine.
