Replaced OEM Air Filter
Old Feb 28, 2005 | 09:30 PM
maxpower's Avatar
Originally Posted by Birdhouse
Where do you buy your K&N Filter (drop in)?
I want to change my own air filter when the time comes. It's a little over 3,500 miles now.
$39 and free shipping:
http://www.ajusa.com/cgi-bin/knfilte...38f62aaa0428d1
Old May 12, 2005 | 11:35 PM
3Aims's Avatar
I replaced mine at 5k and it looked really bad, especially when you consider it's a paper filter. The good news is the replacements are dirt cheap, so changing them every so often does not cost much.
Old May 13, 2005 | 01:15 PM
Beowulf's Avatar
I'm not sure what I missed, but I didn't think changing the filter was not that quick. I unlatched all the clips and unscrewed it from the frame, and I still couldn't get the filter out, so I had to unbolt the whole stupid intake assembly.. I'm I missing something?
Old May 13, 2005 | 01:29 PM
thfx's Avatar
nope, its a real pain but putting a K&N in I will only have to go thru that rarely.
Old May 13, 2005 | 03:31 PM
3Aims's Avatar
I unlatched the clips and bolt. It is very tough, but can be done. After about 20 minutes I was able to pry out the old filter and get the new one in. Not a good design, but it can be done. The big problem is the lower half of the box does not have much room. You have to make sure you use all the space you can down low. Otherwise, the bottom half of the filter will always get stuck. The new filter went in easy becuase you are feeding the filter in at the largest opening. As the new filter works it way down with your hand, you need to use the available room for the lower part of the box. I fed the the new filter with my hand through the air box opening and used the other hand to keep the box spread apart.
Old May 13, 2005 | 11:01 PM
blksnake's Avatar
Smile
Hi all!
I followed Cato's Stock ENGINE Air Filter Replacement DIY instructions found here and it took me <5 mins.
The only suggestion I would add to the DIY is to pickup any loose debris in the air box.
I took her for a drive immediately after the air filter install and felt a definitely felt a difference in throttle response (I only had 12K miles on the old filter). For the cost of the filter (~$8), I think it's the best bang for the buck.
Thanks Cato for the excellent write-up!
Old May 14, 2005 | 01:52 AM
aszatk01's Avatar
K&N @Pep Boys for $45. just put mine in tonight. no brainer to install, just takes some moving around of parts.
Old May 14, 2005 | 09:25 PM
eddie914's Avatar
I just got mine today at Kragen, they have them in stock. they still it for 55.99, but on their web site. it's only 49.99. just print that out and go there, they will match the price for you
here's the link:
http://www.partsamerica.com/ProductD...type=2&ptset=C
I just can't wait for the shipping. I am sure you can find it cheaper online. installing took 5 min. very easy. all you need it's 2 hands Thats it
Old May 14, 2005 | 09:40 PM
SilverII's Avatar
I just took and cleaned my K&N today.... In the process I also removed the resonator below the stock air box.... Hope that helps it breathe easier
Old May 14, 2005 | 10:17 PM
tjlskyline's Avatar
I got a K&N today at Advance for $45, I am a retard when it comes to fixing things and it only took me 15 minutes. About two minutes once I realized there was four clips instead of just the top two...
Old Jun 15, 2005 | 11:51 AM
TheKnite's Avatar
K&N
I've been trying to sell my K&N drop in air filter I had left over from my Maxima for over a month now, and I just realized that 3.5VQ uses the same filter. hahaa I'll be installing that tonite. With all this A/C driving I see a tremendous loss of power comparing it with A/C off, so hopefully that helps a bit.
Old Jun 15, 2005 | 12:05 PM
StockG35's Avatar
Hey MrElussive, How much did you purchase the OEM air filter for at Grubbs? I went for an oil change today and the dealer told me to replace it.....but he was selling it to me for $69.95.
Old Jun 15, 2005 | 12:17 PM
Byte_Me's Avatar
I ordered up my XM radio and antenna splitter from Grubbs prior to even picking up my G last Monday, also ordered the K&N Drop in and a couple other things.
The first thing I did when I got it home from the dealer was to 1. admire how beautiful it is. 2. Call my wife out to see how beautiful it is. 3. Install the K&N filter.
Piece of cake! The only reason I'd do the Z tube or POP charger is for the sound. When I did a CAI on my S2000 I didn't notice any gains at all other than the audible ones!
Old Jun 15, 2005 | 12:59 PM
  #30
Msedanman's Avatar
O.F. Administrator
UGGGGGG, That's nasty....... , You'll save on gas now with the new filter.
C.
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
bTanz
Oct 15, 2015 02:31 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
