G35 shock and strut question
Feb 4, 2017 | 10:08 AM
Dan hope you found the answer you were looking for, KYB excell will give you a factory ride for many miles! Often using is a quicker way to get answers than Driver, they only have one opinion...Gary
Reply 0
Feb 4, 2017 | 08:20 PM
thanks Gary, I did get the shocks ordered. I'll let you know how it all works out.
Reply 0
Feb 5, 2017 | 01:27 AM
I mean they will work out, or they won't. It's oem ride quality.
Reply 0
Feb 7, 2017 | 08:28 PM
ok so I went with Monroe OE Spectrum #71117 and 71116 front struts and #5631 for rear shocks. I also used 4 Monroe strut-mate #SA1997 boot kits. the whole package cost 174.19 delivered. The whole process took about 4.5 hours. Rides smooth.
Reply 0
Feb 8, 2017 | 04:53 PM
I'm going to piggy back onto this thread rather than starting my own.
I have an 03 Coupe w/ sport suspension, and at almost 100k miles, it might not be a bad idea to replace the shocks and struts soon. Is there anything other than the shocks/struts that I should look into replacing while I'm doing the work? Any parts that I have to take off to replace the struts that I should replace since they're out anyway? Bushings, mounts, etc?
Four new shocks are only 270 w/ shipping (KYB) so a bit more for a few extra parts isn't really going to break the bank.
Reply 0
Feb 9, 2017 | 06:58 AM
Shock and strut mounts along with front strut bellows are good to replace at the same time.
Reply 0
Feb 9, 2017 | 02:37 PM
Monroe lists the boot kit SA1997 as coming with the bump stop. "Contains a compression bumper to help prevent severe impacts" IT DOES NOT
but new shocks and struts made a huge difference in the ride
Reply 0
Feb 10, 2017 | 04:30 PM
Quote: Monroe lists the boot kit SA1997 as coming with the bump stop. "Contains a compression bumper to help prevent severe impacts" IT DOES NOT
Thanks for the update, and the tip on the Monroe boot. I'll probably get KYB boots/bellows with bump stops, and Moog shock mounts, since a common theme among KYB mounts is that they squeak.
I think the ride is pretty good on my 03, tbh but at 92k miles I'm sure a refresh wouldn't hurt. Then again I am also coming from a road legal go-kart so pretty much everything feels great by comparison.
Reply 0
Jul 22, 2017 | 10:18 PM
Did replacing strut mounts make your ride less harsh and more gentle over bumps?
Reply 0
Jul 23, 2017 | 02:01 PM
yes changing the shocks and struts made my G35 ride better. But keep in mind it's more of a sports car than a Cadillac.
Reply 0
