Problem with interior lighting
Feb 27, 2017 | 04:34 PM
Anyone else having a problem where you unlock or lock the car or open doors and the dome lights don't turn on?
Works perfect when switch is turned to on but doesn't work when switched to door
Reply 0
Feb 27, 2017 | 05:00 PM
Check the door sensor, it's a little rubber plunger by the production date code on your B pillar.
Reply 0
Feb 27, 2017 | 07:36 PM
What else could it be if it's not that
Reply 0
Feb 27, 2017 | 07:57 PM
A problem with the switch or the wiring possibly.
Reply 0
Feb 27, 2017 | 09:39 PM
No fuses or relays for it?
Reply 0
Feb 28, 2017 | 04:35 AM
If it was a fuse it wouldn't light at all, not sure about a relay.
Reply 0
Mar 1, 2017 | 07:54 AM
Where can I get a fuse diagram for an 03 g35 so I can see if I have all the fuses and right amp I don't have the fuse cover to show me for interior and behind battery
Reply 0
Mar 1, 2017 | 09:18 AM
It's in the engine bay, behind the battery. Remove the passenger windshield lower plastic cowl to access it.
Reply 0
