HELP!!! Rear end vibration under slight load
Old May 17, 2017 | 12:40 PM
hawkku's Avatar
Hi experts! As stated in the title, I'm getting a vibration in my rear end (ostensibly) that ONLY occurs when under very light load and at certain RPMs. I have no idea what is going on and when I am either not on the throttle or on it heavily there is no vibration.
To elaborate; the vibration feels like when you are in a car with 2 15" subwoofers in the trunk and it its a long low beat that rattles the trunk. I have a G35X 2008 with 75k miles on it. Any input is welcome!!!!
Thanks,
Chris
Old May 17, 2017 | 02:50 PM
BradMD_96's Avatar
wheel bearings? Dragging brake calipers? Diff bush? Other suspension bushes? Wheel balance?
Just throwing some ideas out. Have a look underneath for anything obvious.
Old May 17, 2017 | 08:48 PM
hawkku's Avatar
Thanks for the advice! I can't see how it would be a wheel bearing since it only happens at a certain rpm though :/
Old May 17, 2017 | 08:50 PM
hawkku's Avatar
Also Brad, Can you help me on how to check the diff/suspension bushes?
Old May 17, 2017 | 10:37 PM
BradMD_96's Avatar
Signs of cracking on bushes usually mean they are going/gone. They could not be the real root of a problem but either way they need changing. One of our cars had a vibration at highway speeds and seemed to vary with load, fresh bushes reduced the vibration by like 90%.
Start simple though, check the balance of the wheels
