06 G35 coupe knocking sensors misbehavior ?
Old May 26, 2017 | 08:47 PM
ig3506's Avatar
Hello all.
I am concerned about my engine. I put 89 just out of curiosity, half tank.
it is my first refueling on this car which I got 2 days ago.
As I said I put 89 gas and at very low RPM like 1700RPM with gear number 3rd
if I just press a little bit on the throttle (And only if a little bit) I hear for a fraction of second pinging/knocking. It does not happen always but at least 50% of times. At Higher RPMs I cannot feel that, but the engine sound is louder so I am not sure if it is even possible to hear knocking above 2000rpm. I could anyway say I am enough confident there is no knocking above 2000RPM. Knocking (slightly fraction of 1 second)
happens between 1000 and 2000 RPM and usually with Manual/Sequential shift mode with a 3rd 4th gear in, while in drive D mode happens less frequently.
Might I have bad knock sensors ? the pinging just lasts half a second or less...
I'll try with 91 but this engine should not knock at all because the timings are adjusted automatically by the knocking sensors and so the detonation should not occur.
Or am I totally wrong ?
Any hints or experience ? By the way I Can hear the slight fraction of second pinging only if I keep the driver window open, otherwise it is very hard to notice.
I am sure the noise is not something else. The car has new serpentine belts new tensioners and new pulleys brand new stock parts from infiniti and the engine is very quiet, no strange noises.
thanks to all
Old May 27, 2017 | 10:44 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds normal to me. Infiniti recommends premium fuel on the G's but it's fine to run 89. As long as the noise is more of a ping than a knock you should be good to go.
Old May 27, 2017 | 11:35 AM
ig3506's Avatar
yes it is really a slight ping not really a knock
