Nitrous 2004 G35
Nitrous 2004 G35
So I've been told I can run a 100 shot stock. I'm personally have already decided to build bottom end to be safe. I just want to run nitrous I don't plan on going SC or FI. My question is with a built bottom end how much nos could I run.
You'll be lucky if that 100 shot of NOS doesn't blow the welds on the intake.... then Dom and the mad scientist will have to rip apart the block and replace the piston rings you fried.
As long as I win by an inch or a mile.
First of all it wouldnt be just one win. Secondly even if I did it wouldn't matter I have the money to do it and finally if I blow it up I'm perfectly fine with it cause I can go ahead and RB26 swap already.
Are you the mad scientist and just like tearing blocks down?
Why build the bottom end first then? Sounds like you'd be better going straight to the RB swap now and sell your current motor as a working engine to someone else in need and funnel the earned funds into the project rather than blowing it up first.
