I was up all night replacing my rear brake pads, rotors and calipers. I got done at midnight and after bleeding the brakes I went for a spin around the block. By the time I got back and pulled into the garage, a plume of brake smoke wafted around me. I got out and looked at the brakes and the driver's side was glowing cherry red. The passenger's side was fine. I'm scratching my head trying to figure out what happened and what to try next. Any suggestions? The reason I replaced the calipers is because the driver's side started grinding. When I dug into it I found the pad was gone and the caliper was hyper extended. Locked up. Also, there's a whirring sound coming from the engine bay near the brake booster. ABS? Master cylinder? Any ideas?
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:1,045 Times in 960 Posts
Wow. The caliper is sticking. You need to make sure the caliper piston pulls away from the pad after you lift off the brake pedal, if not, it will continue to drag and wear out the brake parts.
Either buy a new caliper, or clean the slide pins and rebuild it.
BradMD_96
close
- Join DateSep 2015
- LocationFlorida, Orlando/Melbourne
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:39 Times in 37 Posts
Yeah and if it sticks again, take pics of the glowing brake disc
it's a brand new caliper and this model doesn't use slide pins.Originally Posted by Urbanengineer
Wow. The caliper is sticking. You need to make sure the caliper piston pulls away from the pad after you lift off the brake pedal, if not, it will continue to drag and wear out the brake parts.Either buy a new caliper, or clean the slide pins and rebuild it.
Quote:
It looked like thisOriginally Posted by BradMD_96
Blue Dream
I drove ttrank's car solo
close
- Join DateMar 2009
- LocationBy the sea, Tx
iTrader Feedback Score(50)
- My RideG35 sedan w/ too much money in mods
Liked:1,488 Times in 1,223 Posts
If you just went for a spin around the block and they looked like that you've got a serious problem. Don't drive it again until you fix the issue......
telcoman
close
- Join DateMar 2011
- LocationCentral NJ
- My RideFront and rear cameras, tire pressure for all four tires can display on screen,folding side view mir
Liked:197 Times in 178 Posts
Quote:
Quote:
Let a pro fix it!Originally Posted by monocogger
Any ideas?
Telcoman
