Knocking sound during idle. Video/audio inside
That doesn't sound good. Sounds like your rod is knocking. Also sounds like the issue that this member is having. How many miles on your car and are you the original owner?
https://g35driver.com/forums/g35-cou...sure-what.html
The problem with knocking like this... especially at idle, is that it can very quickly wear the journals on the crankshaft and throw them out of spec which generally requires a new motor or full bottom end rebuild.
