Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:1,044 Times in 959 Posts
Results look fantastic. You really need to address that front grill though. Paint it black?
150 grit dry d.a.
220 grit dry d.a.
320 wet sand
600 wet sand
800 wet sand
Clear coat
Brings back dead headlights from the dead any day
220 grit dry d.a.
320 wet sand
600 wet sand
800 wet sand
Clear coat
Quote:
It's been that way since the beginning, why change it now? Originally Posted by Urbanengineer
That being said, I'd be open to a smoked/black chrome OEM grille. I don't believe they ever made a "sport" or accessory grille for the 03-07 coupe though? Quote:
220 grit dry d.a.
320 wet sand
600 wet sand
800 wet sand
Clear coat
The 3M kit had a rubbing compound step between the 800 wet sand and clear coat. I found the rubbing compound made quite the difference.Originally Posted by Edgarc6789
150 grit dry d.a.220 grit dry d.a.
320 wet sand
600 wet sand
800 wet sand
Clear coat
Here's another pic:
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
All these results look good, if I had this headlight issue I'd still have a body shop clean & clear my headlights! Done right with professional clear coat, it should last for years!
Gary
Gary
