12V power after the ignition is off
Old Sep 28, 2017 | 01:01 AM
ILuvMyG35's Avatar
Hi guys,
I am trying to hook up my Dashcam to a 12v power after I shut off my g35 so that it will continue to record. Does anyone know where I can tap into a 12v source inside the cabin after shutting off the engine? I assume there might be power at the steering column?
TIA!
Old Sep 29, 2017 | 05:08 AM
.cakestar's Avatar
i mean there are fuses at in the driver panel fuse box that draw directly from battery. you can just use a fuse tap and grab power there but you might end up killing your battery pretty quickly that way
Old Sep 29, 2017 | 06:10 AM
Blue Dream's Avatar
I drove ttrank's car solo
This^^^
Old Sep 29, 2017 | 11:00 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The proper way to do this is to add an adjustable timer-off delay relay circuit from the battery and use one of the ignition-on power circuits from the vehicle as the trigger to start the delay. Here's an example of what you would need.
Amazon Amazon
Black to ground
Red use a 5amp inline fuse and run it to the battery (bolt to the extra post on the IPDM or something)
Blue to some 12v ignition on signal using a fuse tap or something
Yellow to power the camera
Individually cap off white and green, you won't use it.
Obviously this would only work if your camera draws less than 5 amps.
Old Oct 2, 2017 | 09:16 PM
.cakestar's Avatar
ive bought like 5 of these things. they are great.
https://www.amazon.com/Timer-Delay-R.../dp/B00PD65UGA
Black to ground
