Clutch
Old Oct 5, 2017 | 09:09 AM
Boogie2017's Avatar
Clutch
I have a 2007 G35 coupe 6mt need to replace clutch I like to drive fast and just found out I ride the clutch and am trying to break habit. I'm totally obsessed with my car and want it to be best performance. Any suggestions on clutch kit. I'm a girl using phone can't even see what I'm typing to proofread anyway don't need stupid comments just ciutch recommendations.
Old Oct 5, 2017 | 09:14 AM
telcoman's Avatar
Veteran: Army
Don't text and drive
Telcoman
Old Oct 5, 2017 | 09:38 AM
gary c's Avatar
Welcome to G35 Driver Boogie! Two suggestions, keep you foot off the clutch pedal unless shifting and leave your cell in your purse while driving! Now about clutches, unless you're taking your G to the drag strip the factory Nissan clutch will last longer than you'll own this ride! I've owned 4 Nissan vehicles, put well over 100K miles on each of them and never replaced a clutch because it wore out! When you have your clutch replaced don't go to Infiniti, (stealership) Nissan charges 30% less and their mechanics are better trained!
Again Boogie, welcome to driver and enjoy the ride...Gary
Old Oct 5, 2017 | 07:29 PM
Blue Dream's Avatar
I drove ttrank's car solo
OP the fastest way to get stupid comments is to say "Don't need stupid comments" then let us know you're probably texting and driving, that's stupid in and of itself. Your attitude and behavior give us a bad first impression of you. Relax and be comfortable knowing you've joined the best forum on the internet for G35 information. Be humble, post respectfully and hopefully you'll have a long and happy stay as one of our members.
Old Oct 5, 2017 | 08:19 PM
JZ39's Avatar
With any luck this post is a joke.
I simply cannot stand people texting while they drive. It is literally the most dangerous thing you can do behind the wheel aside from being flat passed out drunk.
Texting while driving:
Causes insurance rates to go up, causes car makers to put more and more electronic nannies into cars and will likely be a reason the govt will use to push autonomous vehicles on us and take away our freedom to drive cars in the future.
HANG UP AND DRIVE!!!
Old Oct 5, 2017 | 08:25 PM
sanitarium0114's Avatar
Ive read OP 3 times now and dont see where you guys got that she was texting and driving from...
To op: oem replacement will serve you fine unless you're wanting to get crazy with a ton of extra horsepower mods. Keep working on your proper clutch usage and youll be gold. Welcome to the forums!
Old Oct 5, 2017 | 09:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you're ok with a little clutch chatter and want to go with a lightweight flywheel then check out the marketplace vendors. Usually a cheaper alternative to OEM as well as the performance gained from the reduction of mass on the flywheel, just make sure you also replace the throwout bearing, clutch master cylinder, clutch slave cylinder (operating cylinder) as well as all the fluid.
Old Oct 6, 2017 | 08:33 AM
telcoman's Avatar
Veteran: Army
I only read her post once.
So my questions after reading her post are:
1- Was she texting while driving?
2- Was she on drugs?
3- Was she driving under the influence and texting as well?
4- Why did she not search the forums as there are a ton of threads on clutches?
Telcoman
Old Oct 6, 2017 | 08:34 AM
Urbanengineer's Avatar
Lol ^
There are plenty of threads. She’s just too lazy to look because searching while driving would be hard.
Old Oct 7, 2017 | 07:34 PM
cleric670's Avatar
BANNED!!!
I can understand to a degree since the actual SEARCH button doesn't seem to help a lot but once you know to use GOOGLE search with "g35driver" at the front it's a lot more useful.
Old Oct 13, 2017 | 08:57 PM
saywat?'s Avatar
speeding and riding the clutch wat a moron i dont care that u have a bagina
Old Oct 15, 2017 | 05:26 PM
NemesisGee's Avatar
Unless you are after performance and tracking the car I would not put a single mass flywheel in this car. The G35 drivetrain has pretty harsh torque variations and the vibrations transmitted through the driveline can get very bad. I have a friend with a 350Z who put a single mass a few years ago to save money and the driveline shock was so bad he ended up paying again and put in a DMF067 back inside. This car needs a DMF. The price of this flywheel has dropped dramatically, Amazon is showing $419 shipped (used to be $900-1K 1-2 years ago). RockAuto shows $425. An Amazon kit with Exedy NSK1000 + new slave + Dual Mas Flywheel is showing for $721 shipped. That is an incredible price to put a G35 back to OEM no reason to go with anything else if you are just daily driving.
Old Oct 15, 2017 | 06:58 PM
cleric670's Avatar
BANNED!!!
I recommended it because the OP asked for this:
...I like to drive fast... want it to be best performance.
Old Oct 15, 2017 | 07:25 PM
NemesisGee's Avatar
Yes, I think the OP is a troll but the other side should be stated too.
The car comes with a DMF for a reason. Nissan would have went solid mass if comfort wouldn't be compromised. If the car will see any city traffic driving it will be most unpleasant, I've been in one and it is very annoying in a low rev traffic jam situation. Also, solid mass flywheel isn't going to dampen those torsional vibrations, something else has to give meaning the crankshaft, bellhousing and gearbox essentially become the shock absorber. You could hear and feel metal clashing and banging about. For anyone looking for a 6MT on the used market, I would avoid purchasing any of these cars that have been converted to a solid mass, wear on the drivetrain could be significant, a crank could easily be bent or a bellhousing cracked,
Old Oct 15, 2017 | 07:42 PM
cleric670's Avatar
BANNED!!!
Ehhh, I have a LW clutch, single mass, honestly I don't see the issue other than a little noise. I think by now if there was any significant chance of damage that it would be well known and folks would avoid them.
I agree about the low speed stop n go traffic, it's annoying but you don't even use the gas pedal when releasing the clutch in that kind of traffic so... minimal wear just takes a little practice.
