Hi, This is electrical question for the serious G35 enthusiast/ mechanic. . .
I have an 04 6mt. . . having an issue with the door security lights.
1) When i open the door the light in the panel does not come on. (everything else running on the door elect harness works.)
2) When i close the doors, the dome light and elect light to the switches do NOT turn off.
these two items should function together but dont.
ANy ideas >>??? suggestions? any help appreciated. thanks!!!
-I have checked fuses down on driver side foot well.
-i have checked to make sure the button on chasis is connected (door closes against it properly.
-trunk elect is all currently unplugged
-i have changed the original seats for race seats = so NO elect.reconnected
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
Responded to your other thread but I see you posted in the coupe section so that answers my question from that thread...
When you push the door close switch does the window drop down 1/2" properly? Test both doors, they should function exactly the same.
Both doors are doing the same thing = neither of them turn off the door control power when closed + neither let the door light come on when open.
- The window is not indexing right now as i had the main battery power off for some time and need to reset windows when im all done. I believe mine have a little button onthe motor as they are aftermarket. I have not looked into resetting them just yet as i have more work to do inthe trunk area that requires to have the battery disconnected again.
►do you think the wdw indexing is related to my issue? i can try resetting the motor today.
THANKS Cleric670 - just had a thought. . .
Could a door lock actuator be causing the issue = if it was not working/ malfunctioned on drivers side??
as the driver side has effect on pass side too - it may just be a driver side problem. Like when i disconnect the driver side door harness fromthe body - i found it also shuts down the pass side controls/ power.
update: After testing the door lock actuator and replacing the door panel lights and hooking back up the sun roof/ dome lights.
I found that if i take my 12v auto test light and put the alligator clip on a ground and stuff the point into the door adjar sensor driver side or pass side everythign works. . . . the sensor only runs on 1 wire from the factory. to clarify when i probe that wire with my text light on ground eveything lights up and works as suppose too.
WHat does this mean?? I have an open circuit?? or a short??
