Rev-Up Oil pump
Old Oct 2, 2018 | 10:53 AM
LexD's Avatar
Rev-Up Oil pump
I'm finding two different part numbers for the rev-up oil pump for non rev-up VQ35DE and was curious if they are interchangeable.
15010-AC70A
15010-JK20D
Does the 15010 indicate same part regardless of -XXXXX suffix?
Old Oct 3, 2018 | 02:11 PM
LexD's Avatar
for reference:
15010-AC70A is for VQ35DE
15010-JK20D is for HR and cannot be used on VQ35DE models.
Old Oct 3, 2018 | 02:18 PM
Scorpi0's Avatar
If I remember correctly, the HR pump has softer metal on its propeller or something. Someone should clarify though.
Old Oct 3, 2018 | 02:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
15010-8J10A is the non-revup pump.
15010-AC70A is the revup pump.
Both are interchangeable with one another, and that's correct the HR pump is NOT compatible.
Old Oct 3, 2018 | 02:21 PM
LoSt180's Avatar
JK2 would fit a 370 or VQ35HR engine.
The non-revup oil pump part number is 15010-8J10A
The 15010- indicates the component. In other words all Nissan oil pump part number begin with 15010-xxxxx.
Another example is:
15010-AC70A - Oil Pump
11110-AC70A - Upper Oil Pan
Basically you need the whole number to order the correct part.
cleric670's Avatar
BANNED!!!
No clue I haven't taken any of them apart to compare. Usually higher volume pumps have a larger gear but idk about these ones.
Old Oct 3, 2018 | 02:28 PM
LoSt180's Avatar
There's a pretty good write up on one of the other forums that breaks down the differences if you're really bored. Basically; the revup pump has a 'heavier' gear compared to base, helps with foaming or something at high rpms. The HR pump just has a larger gear compared to the DE and is lighter compared to the revup pump gear. I think since it's larger it doesn't need to be as dense.
G35Bandit
Engine - Complete Motors
Feb 20, 2012 03:36 PM
specialist
Dec 3, 2008 02:06 PM
brotherhef
Forced Induction
22
Nov 18, 2008 08:10 AM
