Timing issue - knock sensor?
Old Oct 9, 2018 | 10:42 AM
Dean Rowell's Avatar
When I went in to have my ABS fixed the shop told me I had a code for my knock sensor that wasnt illuminating the CEL. My scan tool didnt pick up any code, so I made a graph of my rpm and my degrees of spark advance. Does this graph look weird to anyone?
Worth mentioning - i get a measly 16mpg and my acceleration is way slower than i think it should be. I only use 93, and my engine sure doesnt sound like it’s knocking.
Is my knock sensor bad?
why the weird drops in spark advance? is 43 degrees normal for 2000rpm?
Old Oct 9, 2018 | 11:49 AM
eazdaskeez's Avatar
Yup. Knock sensor is bad. Bad knock sensor causes all those issues
Old Oct 9, 2018 | 12:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Anytime the ECM doesn't see the knock sensor circuit it stops advancing timing and returns to the preset baseline, this is exactly what you're seeing on the graph, intermittent drops in timing.
Usually the culprit is the sub-harness on the sensor.
Old Oct 9, 2018 | 12:26 PM
next steps
Is it worth it to go ahead and change both the sensor itself and the sub-harness?
z1 sells the harness for $28 and the sensor for $98
i’m a broke high school student and i’d like to replace only the necessities
Old Oct 9, 2018 | 03:22 PM
cleric670's Avatar
BANNED!!!
If you're broke then do the cheap fix. Plug it in and check for pending codes before putting the manifold back together though.
Old Oct 9, 2018 | 03:24 PM
cleric670's Avatar
BANNED!!!
Err actually ... you wouldn't be able to tell probably because you likely have an intermittent short.
Normally I don't recommend people to use non-oem sensors but get prices from Amazon or something and swap the knock sensor too unless you don't mine tearing into the I take a second time. It's just lost time.
Old Oct 10, 2018 | 01:09 AM
Mission Accomplished
Update: I’ve been at this for eight hours.
Headed over to z1 motorsports and picked up an oem sensor as well as the sub harness, total $136.
It was a royal pain in the *** but I got it installed, took about 4-5 hours. The car thrusts you into the seat harder than it ever has. My gas mileage will undoubtedly improve as well.
The sub harness was 110% shot. It crumbled apart when I tried to unplug it.
I really appreciate all of you guys’ help. cheers.
Old Oct 11, 2018 | 03:24 PM
cleric670's Avatar
BANNED!!!
Awesome, glad everything worked out.
Old Oct 11, 2018 | 07:42 PM
eazdaskeez's Avatar
Awesome! I've done mines a few times and I've gotten my time down to 30 mins lol. Not something I'm to proud of (I bought non oem parts lol)
MIA Philly
Apr 13, 2011 09:14 PM
G352NV
Aug 2, 2005 11:43 AM
