Lot's of loose dash bolts?
Old Mar 5, 2005 | 11:32 PM
roadracer516's Avatar
Just an FYI : So I have this really annoying rattle (go figure) on the passenger side, seems to be near or around the Nav. So today, I started taking the right side of the dash apart to find the culprit (since the dealer can't seem to find it?), got the glove box out, the door to the Nav among a few other items. I found A LOT of loose bolts? The bolts were not loose to the point of coming out, but as I tightened them up, they were noticably loose. I would say I had to tighten 10+ bolts in various places, which leads me to believe that many other are loose within the rest of the dash. I am going to call the dealer on Monday and ask if a tech can go through the entire dash and be sure that everything is to spec, this does not seem to be out of the question IMO, especially with all the rattles my car has? After seeing all these loose bolts, I know for sure that this must be some of the reason I have so many rattles.........we shall see what the dealer says?
Old Mar 6, 2005 | 04:07 AM
Msedanman's Avatar
O.F. Administrator
Good luck at the dealer.
It sounds like you may be on to something there. I wonder if the area was worked on and not put back properly.
C.
linedr89
Aug 17, 2015 05:11 PM
atk08
Jul 30, 2015 03:12 PM
will091195
Jul 27, 2015 09:19 PM
