How do you get rid of door dings???
Old Mar 8, 2005 | 12:11 PM
Kansaijin's Avatar
Originally Posted by GeeWillikers
That ice procedure sounds too good to be true..
Gonna save the post in a .txt in case I ever need it..
I know it does. A lot of body work people recommend against this method because in older cars with bigger dents, if this method is used, it could chip the paint (i.e. when the dent pops back out, the paint flexes and cracks).
However, on most newer cars, with better paint technology/quality, and on small dents, it works well.
It just takes a little bit of legwork and some patience, plus a warm day
I have also heard of people using the ice method on larger dents, but doing it sectionally, one portion at a time. However, I have NO experience with that, so I can't comment on whether or not it would work.
I understand the scepticism, though, I was too.
Old Mar 8, 2005 | 12:31 PM
gDriven's Avatar
Originally Posted by wunautica
Hi everybody,
Oh, btw, I should of gotten a clear bra, cause there are hella rock chips on my hood and front bumper. The only problem with this is that it was really hard for me to find a clear bra installer in my city. Now its too late, oh wells, I could always get repainted, not such a big deal as a massive door dent.
Thanks if anybody could help.
Wu
Wunautica,....since you are in Nor Cal, you should have went with Wil/Sam at Premier Mobile to get your clear bra. Many in the G35 community goes to them for this. I met the guy at a meet a few months back, and saw some of his work. Great guy and incredible work. If you ever need it done, check them out. His user name on here is Wil.
Old Mar 8, 2005 | 03:52 PM
GonSpeed's Avatar
all you need is a small succion (Spelling) cup. place it over the dent, and pull it up.
Old Mar 9, 2005 | 02:50 AM
wunautica's Avatar
Thanks for everybody's responses. I tried the "DING KING" last nite and it didn't work at all. I think that product works best on larger dents, but for dents the size of mine, which is about a nickel, it does't work at all as someone stated earlier in one of the posts above. So people, don't get that product. I read about the dry ice thing. I think I might try this first before having to spend around $75 for a PDR. I called around today and got a few quotes. Now all I need to do is find some dry ice and the cheese cloth shouldn't be so hard. Its been sunny and kinda hot here in Nor Cal, so it should be a good time to do it. I will probably do it this weekend for sure. Lets go from there. If that doesn't work, I will have to set up an appointment to get a PDR done. Thanks everybody and wish me luck. LOVE my car by the way .
I'm thinking about either getting my rock chips fix then get a clear bra now. That or just repaint the car with a stronger paint, I don't know. I'm gonna worry about that later.
Old Mar 9, 2005 | 03:27 AM
Z2G's Avatar
Z2G
i would also recommend using a professional dent repair person. most are mobile and will come to your location. the cost is usually about $75-95 for small dents (about a quarter size or less) and a bit more for bigger dents. my wife has a honda accord coupe and had a huge ding on the door. we called the dent specialist and he came to our office. he charged $95 because it was a huge dent, but it looks pretty good now. you can't really tell there was a dent there at all. those tv self-repair dent kits are worthless....at least that's what i've heard from ppl and consumer reports magazine.
wunautica,
if you want, i can give you the number to the guy i used. i have his business card at my work. i'm also in norcal. he had quoted me $75 for smaller dents, which appears to be the size of your dent.
Old Mar 9, 2005 | 03:49 AM
Premier's Avatar
Unfortunately, these dent removal products and techniques are pretty much useless to removing dents. Taking dents out require careful massaging of the dent from the inside of the panel. The glue pullers will not work in removing dents and in some instances make it even worse. You should search out a PDR tech for the work and bring it back to normal.
Dallsinghjr1
Sep 17, 2023 11:25 AM
TNRocker
Sep 21, 2015 08:36 AM
toadfire
Sep 21, 2015 07:15 AM
jbmw002
Sep 3, 2015 08:42 PM
