Coupe Wheel Dimensions
Old Mar 14, 2019 | 03:12 PM
Venom.1787's Avatar
"Majestic Blue" with aftermarket headlights and a plenum spacer on Kansei Tandems.
I'm unsure of the wheel dimensions on the coupe and I don't understand all the different measurements used. I'm looking for a pair of 18's that look like this one here. If anyone could help explain this to me and maybe even link me to a pair being sold in the US, I would really appreciate it. Thanks in advance. Also, if I posted this in the wrong place then I'm sorry, just let me know and I will move it.
Old Mar 15, 2019 | 09:21 AM
Blue Dream's Avatar
I drove ttrank's car solo
Wheel sizing is easy to understand once you know what the measurements mean. Early coupe sport wheels (the 7 spoke design) for example are 18X8 +30 IIRC. 18=wheel diameter, 8+wheel width and the offset, +30 is how far the face of the wheel sits in relation to the fender line. A +20 offset will sit 5 mm farther out towards the fender edge while a +40 will sit 5 mm more sunken in than the stock measurement.
Armed with this knowledge you can now search for the perfect wheel size and style, happy hunting! I highly recommend you read through this thread if you haven't already, it's a great resource for exactly what each year coupe is equipped with from the factory. https://g35driver.com/forums/g35-cou...s-06-07-a.html
Old Mar 15, 2019 | 03:14 PM
Venom.1787's Avatar
Thanks for responding. I have found a pair that I like and I'm having a difficult time determining the difference between the seemingly identical three options it provides for the measurements I need. If there is a difference, then I would appreciate help in pointing out what exactly it is. Thanks in advance.
Old Mar 16, 2019 | 10:50 AM
Blue Dream's Avatar
The specs for all 3 are identical. However on a coupe, with a 7.5" width and +42 they are going to be very sunken into the wheel well looking out of place. I'd go with wider wheels and a lower offset. 18X8 +25 would look great and fit well.. Plus you'll get better traction with wider tires.
Old Mar 18, 2019 | 06:02 PM
Venom.1787's Avatar
My reply didn't seem to go through the first time, which kinda pisses me off, so here it goes again. Sorry if you end up getting it twice.
I hate to keep bothering you, as I'm trying to figure this all out on my own, but I'm kinda lost on what size I really should be getting, as my current wheels look a bit small imo on top of being not too appealing and curbed by the previous owner. They look like 17" but when I went out and measured them just a minute ago, it said they were about 18.5" in diameter. There's no way in hell that those are 18's, because they look smaller than that to me so maybe I'm just dumb and measuring it wrong? I'd like to get your opinion on what size you think they look like, even though I realize you can't really measure them from the picture. I guess use your judgment and tell me if they really look like 18's or that I'm just imagining things. Thanks for everything so far.
Side profile
Front driver side profile (I feel like they look different from this angle)
Old Mar 19, 2019 | 08:32 AM
Blue Dream's Avatar
No worries, we're here to help. Looks like you have the 03-04 17X7.5" +45 stock wheels. Not sure what you measured but wheel widths are measured from the front edge of the back to the back edge. Did you possibly measure from the outside of the tire to the inside? Here's the wheel I think you have. https://www.partsgeek.com/7xn21f4-in...ad=11620898059
A wheel with 18X8" +25 specs would be wider, taller and closer to the edge of the fender by a significant margin. Remember too that tire sizes will affect the fitment and look of the complete set up.
Deathz_Jester
Oct 1, 2012 03:30 PM
RichesG35
Apr 9, 2011 09:06 PM
InMyHead785
Oct 8, 2007 09:45 PM
imRACERX
Dec 12, 2005 02:51 PM
