Question about G35 Breather Hose
Today I decided to change the valve gasket covers for my g. However when going to take off the breather hoses which are attached to the valve gaskets it made a crack. I was wondering if you guys know any cheap substitute hoses for it. I have looked online for oem breather hoses but since i am trying to sell the car I don't want to waste a bit more money. thank you.
Received 2,457 Likes
on
Coupe 6MT Premium RAS
The problem will be the angles that the OEM hose is bent to. You can use fuel injection line, not regular fuel line it will literally say "fuel INJECTION" on the side and it's rigid enough to not collapse under vacuum but the bends it makes will be tricky unless you buy some 90 degree elbows for it.
It's only like $15 for a silicone hose from Z1 so I'd just go that route, if you wanted dirt cheap then find a G35 at a local pick-n-pull and take one off it.
https://www.z1motorsports.com/z1-pro...it-p-4284.html
waijai
Archived Sales
01-11-2010 01:34 PM
atomevolution
Archived Sales
08-19-2008 12:35 PM
