Weight Reduction
Weight Reduction
First of all, Does taking out 50 pounds here 20 pounds here, really help? I'm a big guy im about 215 pounds.
If I take 200 pounds out, isn't going to make a difference?
And has anyone done any easy quick and not very noticeable weight reduction ?
Originally Posted by jdbinspired
Everything out from the trunk might help somewhat...
Trunk and rear tires are a good idea.
I don't know about you guys, But I like to sit when I Drive, and im sure my Girlfriend would too.
Any other ideas? Trying to make it look stock still keep in mind
Look.....why are you even bothering?
If you wanted a lightweight car, with no interior (hense the lightweight) you should have asked for maybe an Evo...
If you really want to lighten your car, then I think you should sell it, and buy a 350z....that will lose you 200lbs right off the bat. After all, a G35 is just a 350z with stuff added to make it a more luxurious car.
I love my car audio....but I'm also concious of weight....So I have comprised my car audio...also it doesn't help that I'm 270lbs....ahhh but I still have beaten several cars....most notable 04' M3 convertible...yes there were 2 people in the car and the top was down...but I figure I weighed as much as both of them put together.
200 lbs weight reduction = 0.05% weight reduction.
0.05% = small weight reduction
small weight reduction = small acceleration gain
So, no there is no way to reduce the weight enough on the G35 so as to make it noticeably faster without reducing it to a POS worthy of a Kia label.
I got a Lux car cuz I wanted a Lux car, wtf is the matter with wanting a small acceleration gain, Im just looking for some small ways to get a few more torque points
"Every Single Pound Counts"
So mabey I want A Fast luxury car, which is exactly what a G35 Is
aznshodan:
check your math.... 200lbs is 5.7% weight reduction, and it certainly matters
Unless of course you have one of those special 350,000 Lb G's, in which case it is only a 0.057% reduction....
200 LBs is huge as weight reduction goes, and if you shaved 350 lbs, that would be 10%, and have no doubt you'd know it.....
If you could easily add 10% power, you sure would
But beside the point... nothing in the car to give up to drop 200lbs
