No start, no crank, no clicks.
Old Jun 1, 2019 | 09:08 PM
NateKeo's Avatar
Pretty stock, just a plenum spacer and tein coilovers, and exhaust.
Thanks for reading btw Hey guys, having an issue, i was driving my buddy to court and after on the way back when i parked at his house it just didnt want to start at all again. No crank, no clicks, no noise no code. I checked the relays and replaced them and nothing, had the starter checked and it was fine, Battery is fine. Any ideas? Lights and dash lights work fine and radio. Odd thing was one of the times i tried starting it the radiator fan turned on but thats never happened since it happened and this was bout a month ago.
Old Jun 1, 2019 | 10:28 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
So you haven't tried to start it in a month? I would fully charge the battery and try again. If still no start it could be any number of things, bad wire to the starter, bad ground, corroded connection on those systems, bad ignition relay, bad IPDM, bad ECM, bad starter, etc.
Just because you removed the starter and took it down to a shop and they bench tested it while it was cool DOES NOT mean it's functioning properly when hot. A common failure symptom for starters is to start fine when cold but have a no crank when hot.
MooseLucifer
Jul 26, 2018 02:54 PM
ImPoppi
Jul 24, 2012 10:58 PM
deevel79
Jul 6, 2010 11:24 PM
nadir
Jan 19, 2008 12:47 PM
Skaterbasist
12
May 2, 2007 10:27 PM
