2003 G35 Coupe - Intermittent Fan - High to very Low- Replaced Relay/Blower already
Old Jun 27, 2019 | 03:10 PM
G35coupeMD's Avatar
Premium package
A little help please. Newbie G35 coupe owner. I currently just purchased a 2003 G35 coupe project/restoration toy car. The AC/Fan speed is currently intermittent. It usually works on high but than it turns off and on. Fan speed is intermittent. I replaced the relay yesterday with a Nissan OE relay. Still the same symptoms. I just replaced the blower fan with CARQUEST Flanged Vented CCW Blower Motor w/ Wheel from Advance Auto Parts. The old blower motor currently installed was the same part. Is there a blower resistor that I need to replace or is that built in on the ac climate/head unit? Any help/guidance will be appreciated. Trying to resolve it on my own before I take it to a shop to diagnose/resolve😉. Looking at old threads, this forum has helped me already😀 Thanks!! Wife has me on a very limited budget for this additional non need toy car😉 so have to try my best to do everything on this car with my limited mechanical background😉
Other than the current intermittent fan issue, car runs very well considering its age/high mileage..I have always admired the lines of the g35 coupe when it first came out. I am a car guy unfortunately. I use to own 2017 Porsche 911 and a 2017 Corvette C7. For a cheap restoration/toy car compared to some of my past expensive toy cars, I am pretty impressed with overall the balance/ride/responsiveness of the g35😀
FYI: Current reconditioning status/work done
Paint correction: Black paint😉 headlight reconditioning
lowe control arms
ball joints
Automatic Transmission fluid drain/fill
coolant flush
brake flush
pcv valve replacement
engine air filter
cabin air filter
Fixed air bag light issue
Fixed passenger window issue
Future:
spark plugs/coils
throttle body/air flow sensor cleaning
new brake rotors/pads
Edit Quote Multi
Old Jun 27, 2019 | 05:40 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you sure you replaced the CORRECT relay? There are 2-4 relays on the back of Fuse Block - J/B and they're all identical. Pull the relay and see if the fan works, then you'll know if it was the correct one.
Old Jun 27, 2019 | 06:06 PM
G35coupeMD's Avatar
Premium package
Thank you for the feedback sir. From an old thread it looks like I needed to replace the bottom right? I replaced the bottom right closest to the park break. Coupe models only have two relays right? My build date is October 2002.
Old thread:
“Here's a picture looking up from the floor of the car. The blue relay on the right is the winner. I was able to grab it top and bottom and slowly wiggle out.”
From a diagram it looks like the other relay to the left is for accessories?
Do my coupe model have 4 relays? Should I replace top right if it’s available? Guess I will have to get in there again. A Pain in back of fuse box location.
Old Jun 27, 2019 | 06:39 PM
Scorpi0's Avatar
I think your climate control panel is messed up. If its the original, those are notorious for failing and causing all kinda issues.
Old Jun 27, 2019 | 06:54 PM
G35coupeMD's Avatar
Premium package
Well I definitely replaced the right relay after testing both relays. For the hell of it, I switched relays and started working with non intermittent issues. Woohoo! Knock on wood. Hoping this is a long term fix. If not, your right possibly the climate control/possible new JDM DIM unit. Don’t know if wife will approve that though😉.
Thanks guys for the help/inputs. Owe ya guys some beer😉
Old Jun 27, 2019 | 09:16 PM
cleric670's Avatar
BANNED!!!
Yeah on my 2006 it was the relay closest to the brake pedal. Possibly you got a bad relay or possibly it was just a bit of corrosion and the simple act of unplugging/plugging it again scratched off the surface corrosion.
I agree, worst possible place to put a freaking relay...
Old Jun 27, 2019 | 09:44 PM
G35coupeMD's Avatar
Premium package
Just got back from a wishful thinking celebration spirited drive on my fan issue. Unfortunately the climate control fan gremlins came back again. So it looks like I need a new climate control/radio unit or new JDM double DIN kit/radio?
Any other possible fixes/suggestions, please let me know.
Worried that even if I get a new JDM double Din/radio which will be more expensive possible fix, that the intermittent fan problem will still not be resolved.
Thanks..
SiouxFallsG35
Nov 7, 2023 11:35 PM
midnytegsedan
May 23, 2017 01:45 AM
theophilus
V36 General Tech Questions
Feb 16, 2016 09:55 PM
Jawad
Jun 14, 2013 06:14 PM
