just a slight issue with the drivers window ?
when you open and close the drivers door the widow will not always drop and rise ? it works fine when the engine is running . the window will work fine off the rubber switch by the door.
the widows work fine apart from this.
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
Pretty good chance the window regulator is starting to show some wear. Mine started doing this about a year ago, if I apply a little pressure to the top of the glass it will drop but gravity isn't letting it fall on it's own anymore. I opened the door access panel and sprayed white lithium grease on the 4 corner rollers/tracks and ran the window up/down a half dozen times and it's worked fine ever since.
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:1,045 Times in 960 Posts
I had the same issue, and my door window was just torqued a little bit too tight to the window track. Loosening and retightening fixed it.
