Ball joint removal correct tool
Old Jul 30, 2019 | 08:23 PM
Siciliang35's Avatar
Advanced Auto doesn't have the right size in the rental kit. Harbor freight does.
PITTSBURGH® AUTOMOTIVE
14 Piece Master Ball Joint Adapter Set
Old Jul 30, 2019 | 08:35 PM
Scorpi0's Avatar
Old Jul 30, 2019 | 09:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I usually take a mini sledge and whack the steering knuckle a few times and they pop out. Otherwise I use one of these style tools to put pressure on it then whack it with the mini sledge again. I've NEVER had this method fail.
Old Jul 30, 2019 | 10:48 PM
How do you get the ball joints back on?
Old Jul 31, 2019 | 12:12 AM
Urbanengineer's Avatar
You'll need to make sure you have the conical washer. They just slide in and you torque them. Don't over think.
Old Jul 31, 2019 | 01:34 AM
It was pretty quick with that harbor freight tool . Only problem I had is all those surprises. Compression rod bushing is bad and some other things I found
digital sol
Dec 10, 2019 09:20 AM
Siciliang35
Oct 9, 2018 03:15 PM
cswlightning
Apr 17, 2018 02:32 PM
dchen007
May 2, 2006 05:52 PM
