Best rust prevention coating for the "W" transmission tunnel brace
Old Aug 20, 2019 | 03:25 PM
fcp4life's Avatar
04 G35 Coupe Black Obsidian 6MT / Brembo Brake Package
Picked up a used "W" brace in good condition and want to coat it with something that will help prevent rust. Tried searching but couldn't find anything... Should i just spray on some rust encapsulation and then hit it with the 3M rubberized undercoating?
attached some images of the brace below
Old Aug 20, 2019 | 05:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Bed liner coating works great because what happens is you end up with a lot of debris sitting on top of and in the cracks of those things. The bed liner is very impact resistant against rocks and crap flying at high speed.
Body undercoating as well but its usually a 2 part epoxy and not as easy to apply as bed liner.
Lastly your u can always hit it with some cold galvanizing spray (aerosol zinc) then flat black primer, definitely the easiest option and it will add an extra 5 years into the life of that item.
Old Aug 22, 2019 | 08:58 PM
Urbanengineer's Avatar
POR-15 Is pretty solid.
Envious Eric
Apr 20, 2012 08:57 PM
Nikku-
Nov 30, 2009 10:23 PM
GreenGoblin
13
Mar 22, 2009 04:44 PM
XCELR8
Aug 31, 2008 08:31 PM
