Dash cracks "fix"
Old Sep 16, 2019 | 08:35 PM
Polishthrust's Avatar
Dash cracks "fix"
I have been trying to figure out how to fix the cracks in my dash but I was hesitant to use one of those repair kits where you glue it then paint it because the results never look great. Luckily, the cracks in my dash are fairly small but they are still an eye sore. I ended up using some black silicone to fill in the cracks and the results are pretty good. This isn't really a fix, but a pretty decent cover up. Your results will vary depending on the damage on your dash. I just rubbed some of the silicone into the cracks with my finger and wiped off the excess with a wet paper towel.
Unfortunately I don't have great pictures of the Before because I tried other products that did not work well at all. So these Before pictures are actually after a bit of masking, the damage was a bit more excessive at the start.
Before
After
Before
After
Product I used
Old Sep 16, 2019 | 10:46 PM
Scorpi0's Avatar
Nice. I wish I had used that on my dash. I tried using some aircraft grade silicone and it fuct it all up.
Old Sep 18, 2019 | 03:51 PM
Urbanengineer's Avatar
Wow I need to do that to mine great idea.
Old Sep 18, 2019 | 04:22 PM
Rapier4's Avatar
2003 G35 Coupe, Red
Think this will work on larger cracks? I have some larger splits on the door, same material I believe. That looks great
Old Sep 18, 2019 | 07:40 PM
I would give it a go, you might be able to still see them if they are really big but at least they might not be as prominent. Post pictures if you can.
Old Sep 19, 2019 | 02:38 PM
Scorpi0's Avatar
I feel like the bigger the crack, the more visible the difference in color and sheen of the sealant will be, compared to the dash.
So small hairline cracks won’t be noticeable, but a bigger one will. It’ll probably still look better than just leaving it the way it is though.
Old Sep 21, 2019 | 05:55 PM
Mscarlt's Avatar
Laser Red with black interior. Premium package with sport-turned suspenison . 3.5 L DOHC 24 Valve V6
This is good information. I 've been trying to find something for my 2006 G35 dash. I have the same cracks in the same places as you do. Think I will try this product.
Now, if I can get my driver's side door to stay open when I want it to, I will be happy.
Old Sep 21, 2019 | 07:20 PM
FreshLikeAG's Avatar
Replace the hinge, it will help. But the coupe doors are so heavy if you're on the slightest incline it won't stay open
Old Sep 25, 2019 | 07:52 PM
Blue Dream's Avatar
I drove ttrank's car solo
OP the dash looks 1000 times better, nicely done. Is it perfect, no but who cares. It was an inexpensive fix that didn't take a lot of time to do so that's a win, win in my book.
Old Oct 7, 2019 | 09:42 PM
STRYDG's Avatar
Anyone else taken a crack at this? Looks really good. Mine runs along the whole dash and although its not split very wide its just enough to see the colour underneath so hiding it would be nice.
Old Oct 9, 2019 | 06:45 PM
Nissanskylinen1's Avatar
Coupe AT Sport
Nice pun
Mods - should this be stickied?
Old Oct 18, 2019 | 10:23 AM
Lemme ask around.
Old Oct 22, 2019 | 12:37 PM
Supraguy31's Avatar
Veteran: Army
Coupe, Stock
Im going to try it today. I will take some before and after pics.
Old Oct 24, 2019 | 12:21 PM
Blue Dream's Avatar
Awesome suggestion, consider it done.
Old Dec 12, 2019 | 04:13 AM
K1llapanda's Avatar
Just an AEM and lowered. And remote start 😎
Nice
Well done man. I just changed all my tan to black Interior and will definitely be doing this to clean it up. Thank you
