Which side of the AT5 transmission cooler is the hotside?
Some good diys for adding a transmission cooler..but I am still confused about flow and filter direction/placement.
Basic question: Which side of the transmission cooler is the hotside?
Short passenger side hose or long driver side hose?
i.e. Does the coolant flow fron passenger side to driver side or vice versa?
Thanks.
Thanks.
ok started the engine and got the answer!
hotside (Supply to cooler from transmission) is passenger side; coldside (return to transmission from cooler) is driver side
Thanks!
Thanks!
specialist
May 25, 2009 01:11 AM
