no spark
Old Dec 16, 2019 | 02:57 AM
ashleytea666's Avatar
6spd MT, coupe, stock
no spark
im not getting spark, im not sure why, but ive checked the wiring and it gets 12v at the coil and it has ground and the wires between the ecm and the coils are good too.
Old Dec 16, 2019 | 07:42 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
What does your security light do when starting the car?
Old Dec 16, 2019 | 08:04 AM
telcoman's Avatar
Veteran: Army
Start reading!
IPDM, BCM ?
https://www.nicoclub.com/FSM/G35/Cou..._Coupe/str.pdf
Old Dec 16, 2019 | 11:28 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does the tach move when you are cranking the engine? Have you scanned for any hidden codes?
Old Dec 16, 2019 | 02:39 PM
It goes away
Old Dec 16, 2019 | 02:40 PM
No it doesn't move at all, but I can see rpm's when I hook up a scanner.. . And it says there's no codes
Old Dec 16, 2019 | 03:24 PM
cleric670's Avatar
BANNED!!!
I would add a gallon of fresh gasoline to verify there's actually some in the tank, the gas gauge is pretty notorious for failing and showing that you have 1/2 tank when actually you're 100% empty.
Old Dec 16, 2019 | 03:55 PM
That would fix the no spark issue?
Old Dec 16, 2019 | 05:43 PM
cleric670's Avatar
BANNED!!!
Ohhh my bad, I thought you WERE getting spark.
No tach + no spark = usually a crank sensor. Make sure to only replace it with a Hitachi or Genuine Nissan Parts.
Old Dec 16, 2019 | 10:59 PM
ill give it a try
Old Dec 18, 2019 | 12:12 AM
hey so this seems strange to me... but today after i put the ckp back in i went to try and start it and the red security light stayed solid... this is the first time its happening and ive been trying to get this car running for quite some time now...oh and before when i would put the key in the ign. and turn it to on the check engine light would come on, but today when the red light stayed on it was gone
Old Dec 30, 2019 | 04:38 AM
Hey is it possible to do something to the ignition key or accident? One day the key was fine and the red light would go away with the keys in the ignition... But then the next day it's solid red. I'm so confused
Old Dec 30, 2019 | 09:28 AM
cleric670's Avatar
BANNED!!!
Solid red means NATS/IVIS lockout. Key needs reprogrammed probably.
Old Dec 30, 2019 | 09:48 AM
Can it just happen all out of the blue like that though?
Old Dec 30, 2019 | 11:40 PM
cleric670's Avatar
BANNED!!!
It's happened to other users, personally I've never had the issue.
EDIT: It's also possible for the RFID chip in the key to lose it's signal over time, do you have a second key you can try?
biscuitownz
V36 Engine, Exhaust, Drivetrain & FI
Dec 26, 2017 02:24 AM
sanchamp411
Dec 30, 2015 07:49 AM
jtor181
Jun 21, 2014 12:31 PM
butkiss1
Nov 30, 2008 02:35 AM
pprkut
Aug 20, 2008 02:54 PM
