Fuel pump problem
Old Dec 19, 2019 | 10:11 PM
1moremod_vq35's Avatar
2005 Infiniti g35 coupe w bolt ons
Fuel pump problem
Hello all, this is my first post on here so sorry if it’s not in the right category but here’s my problem. I recently bought another 05 Infiniti g35 manual trans, and the problem with it is it won’t start, it will crank but no start. The thing is I can’t hear the fuel pump prime, I checked every fuse, and also replaced the fuel pump but still no luck. So I took the fuel pump and put power to it via a jump box and it was squirting fuel, so it’s not like there’s something wrong with the fuel pump, then I took the intake off and sprayed starting fluid into the throttle body and sure enough the car starts right up. So there’s some kind of disconnect from ignition to the fuel pump. Also worth mentioning the car was repossessed so my thoughts were maybe something security related? Any advice would be extremely helpful, thank you.
Old Dec 20, 2019 | 09:06 AM
telcoman's Avatar
Veteran: Army
Any Codes?
Old Dec 20, 2019 | 09:07 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Sounds like the NATS security has been tripped. What does the security light do when the key is turned to start?
Old Dec 20, 2019 | 11:51 AM
Originally Posted by telcoman
Any Codes?
no codes show up at all
Old Dec 20, 2019 | 11:53 AM
I’m actually not sure what the light does but if it was the NATS how would I go about resetting it?
Old Dec 20, 2019 | 03:33 PM
telcoman's Avatar
Veteran: Army
The FSM would be a good place to start your troubleshooting.
http://www.nicoclub.com/FSM/G35/Coupe/2005/sc.pdf
See page SC -10
STARTING SYSTEMPFP:23300System Description AKS003Z1M/T MODELPower is supplied at all times through 40A fusible link (letter M, located in the fuse and fusible link block)to ignition switch terminal 1,through 10A fuse (No. 71, located in the IPDM E/R )to CPU of IPDM E/R,through 15A fuse (No. 78, located in the IPDM E/R)to CPU of IPDM E/R.With the ignition switch in the ON or START position, power is suppliedfrom ignition relay (located in the IPDM E/R) to 10A fuse (No. 89, located in the IPDM E/R)through IPDM E/R terminal 25to clutch interlock switch terminal 1.When the clutch pedal is depressed, power is supplied through clutch interlock switch terminal 2 to IPDM E/R terminal 53.Ground is supplied to IPDM E/R terminals 38, 50 and 60from grounds E17 and E43.Then starter relay is turn ON.With the ignition switch in the START position, IPDM E/R is energized and power suppliedfrom ignition switch terminal 5to IPDM E/R terminal 4 and through IPDM E/R terminal 3 to starter motor terminal 1.The starter motor plunger closes and provides a closed circuit between the battery and starter motor. The starter motor is grounded to the engine block. With power and ground supplied, cranking occurs and the engine starts.
Perhaps your IPDM is defective or an open or corrosion in your wiring harness?
Or
http://www.nicoclub.com/FSM/G35/Coupe/2005/ec.pdf
See page EC- 45
IVIS (INFINITI VEHICLE IMMOBILIZER SYSTEM-NATS)PFP:28591DescriptionABS00E3IIf the security indicator lights up with the ignition switch in the ON position or “NATS MALFUNCTION” is displayed on“SELF-DIAG RESULTS” screen, perform self-diagnosticresults mode with CONSULT-II using NATS program card.Refer to BL-115, "IVIS (INFINITI VEHICLE IMMOBILIZERSYSTEM-NATS)" .Confirm no self-diagnostic results of IVIS (NATS) is dis-played before touching “ERASE” in “SELF-DIAG RESULTS”mode with CONSULT-II.When replacing ECM, initialization of IVIS (NATS) systemand registration of all IVIS (NATS) ignition key IDs must becarried out with CONSULT-II using NATS program card.Therefore, be sure to receive all keys from vehicle owner. Regarding the procedures of IVIS (NATS)initialization and all IVIS (NATS) ignition key ID registration, refer to CONSULT-II Operation Manual,IVIS/NVIS.
VIN Registration is an operation to registering VIN in ECM.
You might want to consider calling AAA for a free tow to your nearest Infiniti dealer to pay the diagnostic fee, run the VIN number to tell you where the original purchase was made, its service history, and to diagnose your problem with the consult lll saving you lots of time and not replacing unnecessary parts.
Old Dec 20, 2019 | 07:19 PM
See page SC -10
Or
See page EC- 45
Thank you for your reply, I think my best bet would be to get it towed to Infiniti and see what they can do, something with the security might have been triggered when the vehicle was repo’d
Old Dec 21, 2019 | 07:35 AM
telcoman's Avatar
Veteran: Army
Prior to doing that make sure you have a clear title to that vehicle with no Liens on it.
Old Dec 21, 2019 | 05:51 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The NATS/IVIS indicator light is on the left side of the dash, not part of the instrument cluster. There is a small LED light embedded in the dash, if NATS/IVIS is interlocking the ignition it will be SOLID RED when you are trying to crank the engine.
Ace Fox
Jul 2, 2017 01:47 PM
Calipat916
Jan 14, 2016 02:43 PM
KeepinItG35
Nov 17, 2013 08:45 AM
