Please Help very frustrated
Old Jan 4, 2020 | 08:03 AM
chasracer's Avatar
Always go back to the last thing you did - which you attempted to do a couple of times. At that point you should have hit the books and requested help but no, let's do the same again and expect different results. All of us make mistakes, it's the ability to quickly realize it and possibly save the mess that's important. A simple plug change should never end up with an engine running worse. And honestly I have had plugs out on a number of these engines and with a little observation and care, mixing up coil pack wires is a bit hard to do. Not impossible of course but I would have looked for a vacuum line knocked off or a sensor connection askew too.
Old Jan 5, 2020 | 07:42 AM
telcoman's Avatar
Veteran: Army
Originally Posted by Homero Perez
only problem with that is that I’m in college, I don’t quite have the funds to have the dealership deal with it. It’s very frustrating that I go to do a basic tuneup put everything back together and the car runs like a piece. If me not taking it to the stealer ship is such an issue maybe you should just send me the money and I’ll do as you say
If you are a college student without a full time job you bought the wrong car. Most parts are at or near end of life and very expensive. Buying cheap non oem parts are going to cost you lots of your wasted limited funds.
Frost_Tech
Feb 8, 2017 04:41 PM
G-zus35
Oct 5, 2011 03:11 AM
lilDee
14
Feb 26, 2009 02:20 AM
High3nd_SD_g35
Jun 16, 2008 03:50 AM
