2003 G35 Sedan
Old Feb 8, 2020 | 11:19 AM
teemason's Avatar
G35 Sedan
2003 G35 Sedan
My G35 has 135000 miles on it and I noticed that the transmission is starting delay/slip as I press the accelerator at slow speeds. I read that a complete flush could do more damage. A mechanic suggested putting more fluid in it just to see if the level was low. Any suggestions?
Old Feb 8, 2020 | 12:22 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I suggest checking the fluid level first. Get the tranny up to temp (go for a 15 minute drive), park the vehicle with the engine still running, manually shift down through each gear and let it sit in each position for a second or two, then back up through each gear, put the vehicle in park with the engine STILL running.
Dipstick requires a 10mm socket to remove the retainer bolt, remove, wipe, replace, do this 7-8 times to get all the extra fluid out of the tube, then take 3 more readings wiping the dipstick each time. I believe the difference between the high and low hash marks is exactly one PINT which is 1/2 quart.
Just out of curiousity, have you been neglecting the maintenance on your transmission? The pan should be drained and filled every 30k miles. I question the reliability of your mechanic if he didn't check the fluid level and is suggesting to add more...
Here's a good read on automatic transmissions and changing fluid.
https://g35driver.com/forums/g35-sed...ml#post7123536
Old Feb 8, 2020 | 01:06 PM
teemason's Avatar
G35 Sedan
he did suggest checking the levels before adding fluid. He took the bolt off but there was no dipstick there.
Old Feb 8, 2020 | 01:40 PM
cleric670's Avatar
BANNED!!!
Go down to your local Nissan or Infiniti dealership and buy part number 31086-CD100
Some of the early G35 only had that cap without a dipstick, it's like $20 for the dipstick, alternately you can go to a pick-n-pull and take one off a 2003-2007 350Z with an automatic transmission. That Nissan part number is the 350Z dipstick which works in the tube that's equipped on your style of transmission.
Old Feb 12, 2020 | 02:28 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
You are correct that 'flushing' a trans can cause issues, these cars you do a drain/refill easily since the pan has a drain bolt. If you are mechanically inclined, I'd drain the fluid out and see how it looks. Its only 3.5-4qts. Heck, it might even have the wrong spec fluid in it, which is known to cause issues with these cars.
I personally would use Idemitsu Type-J or OEM Matic-J (some online vendors still have it in stock). I pick them over the Matic-S, especially if you have slipping issues. From what I've heard, they apparently they changed the additive package with Matic-S to make shifts softer for the 7AT trans in newer G/Q's. My 04 G shifts more consistently with the J spec fluid compared to S.
Jvillian914
Mar 31, 2016 04:24 PM
G35betty
Apr 5, 2005 03:36 AM
