Car Troubles
Old Mar 9, 2005 | 09:55 AM
coolice's Avatar
Car Troubles
Hey all,
Well i must say that i am pretty pissed, my car had to be flat bedded to the dealer last night with only 4800 km on it . It all started after the gym, i had driven there without a problem, i did my workout but when i got out of the gym i started the car and the Service Engine soon, the VDC and the Slip light were on. The car went into limp mode, has anyone had this happen to then?? What would cause this on a car with such low mileage??
Martin
04 G35 Coupe 6MT without NAV
Old Mar 9, 2005 | 10:11 AM
Hotrod's Avatar
Originally Posted by coolice
Hey all,
Martin
It may be as simple as a bad maf sensor, I am sure they will find and fix the problem in no time.
Old Mar 9, 2005 | 10:26 AM
coolice's Avatar
Bad MAF, damn, i have a K&N in there could that be the cause since those things are oiled up? How much would a MAF be?
thanks,
Martin
Old Mar 9, 2005 | 10:59 AM
Hotrod's Avatar
yes an oiled up k&n could easily mess up the MAF sensor at least it was a problem on the nissan vqs in 02-03. All you can do is wait until they check it out. they may not even notice the k&n if it is in the stock air box. I assume they gave you a loner car!
Old Mar 9, 2005 | 08:22 PM
weaksauce's Avatar
It all started after the gym...
maybe the car went into limp mode cause it was scared how buff you looked after the gym! ok, sorry, j/k. two smart assed posts from me in one night! must be in one of those moods. i should prolly log off before i am declaired bad at the internet....
Old Mar 9, 2005 | 08:32 PM
GurgenPB's Avatar
You could have done a simple gas pedal reset and that would taken the car out of a MA-induced limp mode, that would be a good way to check. But, given that the VDC/Slip came on as well, I am not 100% sure that it is the MAF, but it still very possible.
Old Mar 9, 2005 | 08:47 PM
Alonjar's Avatar
Originally Posted by GurgenPB
You could have done a simple gas pedal reset .
This may be a stupid question but, what do you mean gas pedal reset?
Old Mar 9, 2005 | 09:11 PM
weaksauce's Avatar
reset ecu...
https://g35driver.com/forums/engine-drivetrain-forced-induction/6526-easy-ecu-resetting.html
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
