View Poll Results: Car is fine?
Yes
0%
No
100.00%
Voters: 2. You may not vote on this poll
Colder spark plugs
Old Jul 15, 2020 | 09:00 PM
Arturo Mireles's Avatar
Blue g35
Colder spark plugs
Hopefully someone can help me i recently installed 2 step colder spark plugs because im planning on spraying 100 shot of nitrous and now white smoke is coming out under the engine and exhaust, i was told it was the unburn fuel making it safer for a bigger shot of nitrous. Is my car okay to drive ?
Old Jul 15, 2020 | 10:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Wet or dry kit? Any smoke coming from the engine bay should be immediately investigated. I don't know the context of what you were told but it sounds like total bullshit.
Old Jul 15, 2020 | 10:10 PM
Blue g35
Wet kit and what do you think the white smoke is from then?
Old Jul 15, 2020 | 10:12 PM
cleric670's Avatar
BANNED!!!
Oil burning off something is the most likely culprit. Get the car up in the air and find out.
Old Jul 16, 2020 | 12:35 AM
Blue g35
I dont think so because its coming out of the exhaust and if you dont have anything helpful stop wasting my time
Old Jul 16, 2020 | 11:33 AM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Cleric is one of the most helpful members of this forum, you may want to re-think your attitude. If you dig further into your problem and provide better details, you'll get more useful information from this forum.
When you replaced your plugs were any of the old ones covered in oil?
Old Jul 16, 2020 | 03:07 PM
Blue g35
yeah im gonna have the head gasket replaced
Old Jul 16, 2020 | 03:26 PM
SoCal04G35's Avatar
MODERATOR DELETE
Please read the forum rules, specifically #10
https://g35driver.com/forums/faq.php...aq#faq_faq_tou
Old Jul 16, 2020 | 03:36 PM
Blue g35
MODERATOR DELETE
Old Jul 17, 2020 | 07:56 AM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Old Jul 17, 2020 | 12:48 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Old Jul 17, 2020 | 01:24 PM
cleric670's Avatar
BANNED!!!
You guys are making my job harder, now I have to edit out a bunch of posts. For the future please don't engage in this kind of back and forth on the forums, I'm not going to issue any strikes just give a verbal warning.
As for the smoke coming under the hood I still recommend checking everything with the car on a lift IF IT WAS IN FACT SMOKE.
If it wasn't smoke then it might have been coolant steam, nitrous install typically has a purge valve as well that you will use to clear vapor from the line to make sure you only have liquid NOS in the line. I don't think this is what you were seeing though because it's a manually activated button and you would know you were purging.
If you suspect any engine damage get a compression and leakdown test. You might have pushed the HG a little and it would definitely show on those tests.
Old Jul 17, 2020 | 02:02 PM
Blue g35
Thank you cleric i didn't mean any disrespect and those guys started the name calling.
Old Jul 22, 2020 | 05:46 PM
chasracer's Avatar
Maybe so, maybe not.
Who put the plugs in it? Any codes? Any other operational issues?
Drty5
Feb 5, 2020 10:52 PM
